The 50 cm Blue CAT8 Ethernet Cable by StarTech.com offers performance for high-speed network connections. This patch cable adheres to IEEE 802.3bt/IEEE 802.3ba standards, ensuring reliable data transfer rates of up to 40 Gbps. Constructed with pure bare copper conductors and reinforced with aluminum mylar foil shielding and braid, this cable provides excellent EMI protection and is flame-retardant, making it safe for various environments.
With a robust design featuring strain relief and capable of withstanding up to 750 mating cycles, this cable ensures durability and longevity. It is equipped with low smoke zero halogen (LSZH) jacket material, emphasizing safety and low emissions. Additionally, this cable is compliant with TIA/EIA T568B wiring scheme, supporting 100 W PoE++ for versatile networking needs.
High-speed performance
This Ethernet cable offers transfer speeds of up to 40 Gbps, ensuring efficient data handling for demanding applications. -
Durable construction
Featuring strain relief and capable of withstanding 750 mating cycles, this cable is built to last, promoting reliability in network setups. -
Superior shielding
Aluminum mylar foil with braid shielding provides excellent EMI protection, reducing interference for a stable connection. -
Safe and compliant design
Designed with a low smoke zero halogen jacket, this cable adheres to safety standards for use in sensitive environments. -
Versatile compatibility
Compliant with TIA/EIA T568B standards and supporting 100 W PoE++, this cable accommodates various networking applications.
- StarTech.com 50cm Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 50 cm - blue
- Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Shielding Material
- Aluminum mylar foil with braid
- Wires per Cable
- 8 wires
- Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
- Length
- 50 cm
- Diameter
- 5.6 mm
- Core / Cladding Diameter
- 50 micron
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- 50 micron
- Plated Connector
- Gold
- Length
- 50 cm
- Diameter
- 5.6 mm
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- TIA/EIA T568B - up to 2000 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 0.8 cm
- Shipping Weight
- 37 g
- 0 °C
- 50 °C
