The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, our shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
High performance speed
This cable supports transmission speeds of up to 10 Gbps, making it suitable for high-demand applications like online gaming and HD video streaming. -
Enhanced safety design
The Low Smoke Zero Halogen jacket material significantly reduces the release of toxic smoke during combustion, ensuring added safety in enclosed spaces. -
Robust construction
Featuring strain reliefs and damage protection, this cable is built to withstand the rigors of everyday use, reducing the risk of cable wear and tear. -
Reliable shielding
With S/FTP technology, this cable provides protection against EMI and RFI interference, ensuring a stable and reliable connection. -
Eco-friendly compliance
The cable adheres to RoHS, ETL, and other environmental standards, demonstrating a commitment to safety and sustainability in its manufacturing process.
- StarTech.com 50cm CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 50 cm - white
- Patch cable - CAT 6a - IEEE 802.3bt
- Technology
- S/FTP
- Shielding Material
- Foil
- Wires per Cable
- 8 wires
- Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Foil
- Jacket Material
- American Wire Gauge (AWG)
- 27
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 50 cm
- 25.5 g
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 0.8 cm
- Shipping Weight
- 34.2 g
