StarTech.com 50cm CAT6a Ethernet Cable LSZH - White
Quicklinx: H15PWS00 Mfr#: NLWH-50C-CAT6A-PATCH
Length: 50cm
Colour: White
22 In Stock
£7.04 ex VAT
£8.44 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, our shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • High performance speed
    This cable supports transmission speeds of up to 10 Gbps, making it suitable for high-demand applications like online gaming and HD video streaming.
  • Enhanced safety design
    The Low Smoke Zero Halogen jacket material significantly reduces the release of toxic smoke during combustion, ensuring added safety in enclosed spaces.
  • Robust construction
    Featuring strain reliefs and damage protection, this cable is built to withstand the rigors of everyday use, reducing the risk of cable wear and tear.
  • Reliable shielding
    With S/FTP technology, this cable provides protection against EMI and RFI interference, ensuring a stable and reliable connection.
  • Eco-friendly compliance
    The cable adheres to RoHS, ETL, and other environmental standards, demonstrating a commitment to safety and sustainability in its manufacturing process.
StarTech.com 50cm CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 50 cm - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
25.5 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.8 cm
Shipping Weight
34.2 g
Length: 50cm
Colour: White
