StarTech.com 50cm CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H15BWS00 Mfr#: NLBL-50C-CAT6A-PATCH
Length: 50cm
Colour: Blue
30 In Stock
£6.78 ex VAT
£8.13 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 50cm - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • High-speed performance
    This cable supports data transfer speeds of up to 10 Gbps, ensuring fast and efficient communication between devices.
  • Comprehensive shielding
    Featuring S/FTP technology, this cable offers excellent protection against electromagnetic interference, ensuring a clear and uninterrupted signal.
  • Safe and reliable construction
    The Low Smoke Zero Halogen (LSZH) jacket enhances safety by reducing smoke emissions in the event of a fire, making it an ideal choice for various environments.
  • Durable design
    Equipped with strain reliefs, this cable minimizes the risk of damage from pulling or bending, contributing to its long-lasting performance.
  • Certified compatibility
    With compliance to IEEE 802.3bt and other standards, this cable meets the requirements for modern networking applications.
StarTech.com 50cm CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 50 cm - blue
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
25.5 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.8 cm
Shipping Weight
34.2 g
Length: 50cm
Colour: Blue
