StarTech.com 50cm CAT6a Ethernet Cable LSZH - Black
Quicklinx: H151WS00 Mfr#: NLBK-50C-CAT6A-PATCH
Length: 50cm
Colour: Black
16 In Stock
£6.73 ex VAT
£8.07 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 50cm - Black - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Safe construction
    The cable jacket is made from Low Smoke Zero Halogen (LSZH) materials, reducing toxic smoke emissions in case of fire, which is particularly beneficial in tight spaces.
  • High-speed performance
    With support for data transfer rates up to 10 Gbps and a frequency of 500 MHz, this cable is engineered for fast and efficient network connections.
  • Advanced shielding
    Employing S/FTP technology and foil shielding, this cable minimizes electromagnetic interference and ensures signal integrity, enhancing overall performance.
  • Robust connectors
    Featuring gold-plated RJ-45 connectors, this cable ensures reliable connections with reduced risk of corrosion, maintaining optimal conductivity.
  • Flexible usability
    This patch cable can comfortably deliver up to 100 watts of power over Ethernet to devices, making it suitable for various network setups and powered devices.
StarTech.com 50cm CAT6a Ethernet Cable - Black - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 50 cm - black
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
25.5 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.8 cm
Shipping Weight
34.2 g
Length: 50cm
Colour: Black
