Install your rack-mountable hardware securely with these high-quality screws. This 50-pack of M6 mounting screws is convenient to have on hand for installing rack-mountable equipment, such as your server, network or audio/video equipment.
They are also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a screw or two. The bulk package ensures that you have enough screws available for all of your installations, when you need them. The server rack screws come in an all-black finish for a seamless look.
- StarTech.com M6 x 12mm - Screws - 50 Pack, Black - M6 Mounting Screws for Server Rack & Cabinet (CABSCREWSM6B) - screw kit
- Product Type
- Screw kit
- Packaged Quantity
- 50 (specifications are for single item)
- Package Content
- M6 screw
- Black
- Product Material
- Steel
- 0.6 cm
- 2-year warranty
- Designed For
- P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2, WALLMOUNT4
- Packaged Quantity
- Product Type
- Screw kit
- Product Material
- Steel
- Package Content
- M6 screw
- 0.6 cm
- Black
- Limited warranty: - 2 years
- Designed For
- P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK3236BKF, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLMNT12, WALLMOUNT4, WALLMOUNT6, WALLMOUNT8, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £210.18 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £199.11 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £170.86 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £57.09 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.44 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £29.06 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.99 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.75 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £28.49 |
StarTech.com 2-Post Server Rack - 42U | In Stock | £149.26 |
