StarTech.com 50 Pkg M5 Mounting Screws
Quicklinx: BT5FWS00 Mfr#: CABSCREWSB
Product Type: Screw kit
£15.48 ex VAT
£18.57 inc VAT
Install your rack-mountable hardware securely with these high-quality screws. This 50-pack of M5 mounting screws is convenient to have on hand for installing rack-mountable equipment, such as your server, network or audio/video equipment. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
They are also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a screw or two. The bulk package ensures that you have enough screws available for all of your installations, when you need them.
The server rack screws come in an all-black finish for a seamless look.
StarTech.com M5 x 12mm - Screws - 50 Pack, Black - M5 Mounting Screws for Server Rack & Cabinet (CABSCREWSB) - screw kit
Screw kit
Packaged Quantity
50 (specifications are for single item)
Package Content
M5 screw
Product Material
Steel
0.5 cm x 1.2 cm
210 g
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2, WALLMOUNT4
Packaged Quantity
Screw kit
Product Material
Steel
Package Content
M5 screw
0.5 cm
1.2 cm
210 g
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK3236BKF, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLMNT12, WALLMOUNT4, WALLMOUNT6, WALLMOUNT8, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
BT5F StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £203.32
BT5F StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £192.50
BT5F StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £165.22
BT5F StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BT5F StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
BT5F StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
BT5F StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
BT5F StarTech.com 2-Post Server Rack - 42U In Stock £144.32
