StarTech.com 5-Speed Ethernet Network Card
Quicklinx: C90SWS00 Mfr#: ST10GSPEXNB
Add an Ethernet port to a server or workstation, with support for five network speeds: 10G/5G/2.5G/1G/100 Mbps. This 5-speed network adapter card offers versatile and cost-efficient network connectivity. It lets you add an Ethernet port to your server or desktop computerand access your network at multiple speeds: 10G, 5G, 2.5G 1G and 100 Mbps.
Designed for low-power, single-port network applications, the PCIe NIC offers a cost-effective and versatile networking solution by providing additional bandwidth to meet your network needs, without having to overhaul your infrastructure wiring. Fully compliant with 10GBase-T and NBASE-T specifications, the network card lets you add an Ethernet port to your server or high-powered workstation through a PCI Express x4 (or higher) slot.
The network controller card features advanced NBASE-T technology, supporting the latest multi-gigabit, including Cisco campus switches and Aruba Networks access points. The card enables you to connect to NBASE-T based equipment at network speeds of 2.5Gbps or 5 Gbps, over your existing Cat5e infrastructure, without having to upgrade to more expensive Cat6a.
NBASE-T technology accelerates the speed of twisted pair Cat5e copper cabling over a distance of up to 100 meters. The Ethernet network card also supports the more common 10G over copper, and 1G network connections using existing Cat 6/Cat5e or better cabling.
The 5-speed Ethernet network card is a powerful combination of the Tehuti TN4010 controller and the Aquantia AQR105 transceiver, providing low-power and high-performance NBASE-T solutions. The Tehuti 10GbE controller supports autonegotiation, which ensures the optimal speed over Cat5e/Cat6 is selected: 10GbE, 5GbE, 2.5GbE, GbE or 100Mbps (Fast Ethernet). The network card also offers compatibility with Microsoft Hyper-V virtualization software and iSCSI support to combine LAN and SAN functions.
The Tehuti TN4010 chipset, compliant with 802.3az Energy Efficient Ethernet, ensures peak operating efficiency with reduced power consumption versus the popular Intel X540 chipset. The decreased power consumption helps to minimize heat generated by the card, to avoid increasing the operating temperature within your server case.
The network card also supports advanced features including 16K Jumbo Frames and 802.1q VLAN tagging. For additional versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com 1 Port PCI Express 10GBase-T / NBASE-T Ethernet Network Card - 5-Speed Network Support: 10G/5G/2.5G/1G/100Mbps - PCIe 2.0 x4 (ST10GSPEXNB) - network adapter - PCIe 2.0 x4 - 1000Base-T x 1
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x4
PCI Specification Revision
PCIe 2.0
Ports
1000Base-T x 1
2.1 cm x 8.3 cm x 12 cm
100 g
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Data Transfer Rate
10 Gbps
Tehuti / Aquantia TN4010 / AQR105
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3an
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, VMware ESXi 5.1, VMware ESXi 5.0, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, VMware ESXi 6.0, VMware ESXi 6.5, Microsoft Windows Server 2019, Linux 3.x - 4.14 LTS versions only, Apple macOS 10.12 - 10.14
Network adapter
PCI Express 2.0 x4
PCIe 2.0
Ports
1000Base-T x 1
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity, link/speed
Full duplex capability, VLAN support, auto-uplink (auto MDI/MDI-X), Link Aggregation
Processor / Memory
1 x 10GBase-T - RJ-45
Low-profile bracket
Software Included
Drivers & Utilities
2.1 cm
8.3 cm
12 cm
100 g
5 °C
50 °C
C90S StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £18.28
C90S StarTech.com 1-Port Gigabit NIC - PCIe In Stock £27.80
