StarTech.com 5 Ports Industrial Ethernet Switch
Quicklinx: B4HRWS00 Mfr#: IES5102
Type: Fast Ethernet
Ports: 5
Data Transfer Rate: 100Mbps
Managed: No
POE: No
Hurry, only 1 left in stock!
£63.79 ex VAT
£76.54 inc VAT
Expand your network connectivity with this rugged unmanaged 10/100Mbps switch. This compact 5-port industrial Ethernet switch is engineered to deliver fast, reliable network connectivity and durability in the most demanding industrial environments. It provides top performance in a wider range of operating temperatures than conventional network switches, making it ideal for factories and warehouses.
Designed with a rugged IP30-rated housing, the network switch delivers maximum performance even in harsh industrial conditions. Its wide-range terminal block input gives you the flexibility to power the switch as required, based on your own power input source, while its wide operating temperature range keeps your network running smoothly.
This industrial Ethernet switch is easy to install, with an attached metal bracket for DIN rail mounting on equipment racks and cabinets.
Now you can eliminate the hassle of troubleshooting mismatched speed and duplex settings. This switch gives you full/half-duplex auto-negotiation and auto MDI/MDIX operation, enabling you to connect your network devices quickly and easily with little to no configuration required.
With lower overall power consumption, the Ethernet switch enhances your energy efficiency, in turn helping you reduce monthly costs.
  • Conquer the tough demands of industrial environments
  • Get up and running in no time
    This industrial Ethernet switch is easy to install, with an attached metal bracket for DIN rail mounting on equipment racks and cabinets. Now you can eliminate the hassle of troubleshooting mismatched speed and duplex settings. This switch gives you full/half-duplex auto-negotiation and auto MDI/MDIX operation, enabling you to connect your network devices quickly and easily with little to no configuration required.
  • Reduce your energy costs with energy-efficient Ethernet
StarTech.com 5-Port Ethernet Switch - 10/100Mbps Industrial Networking Solution - IP30-rated Energy Efficient Internet Switch (IES5102) - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, QoS, Jumbo Frames support, plastic housing, Energy Efficient Ethernet, 56KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
11 cm x 7 cm x 2.5 cm
148 g
P/N: NETRS2322P
Enclosure Type
DIN rail mountable
Subtype
Fast Ethernet
Ports
5 x 10/100
Status Indicators
Power, active, link/activity
4 x 100Base-TX RJ-45 , 1 x 100Base-TX RJ-45 uplink
External power adapter
2.12 Watt
3-pin power terminal block
MTBF
1,179,133 hours
EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, FCC, EN 61000-6-2, RoHS, EN 61000-4-8, EN 61000-6-4, IEC 60068-2-27, IEC 60068-2-6, IP30
11 cm
7 cm
2.5 cm
148 g
-10 °C
60 °C
10 - 90% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
85 °C
Humidity Range Storage
P/N: NETRS2322P
B4HR StarTech.com 5 Port Industrial Gigabit Ethernet Switch In Stock £135.72
B4HR StarTech.com Unmanaged 2.5G Switch - 5 port In Stock £42.34
Type: Fast Ethernet
Ports: 5
Managed: No
POE: No
