StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 Power over Ethernet ports
Installation required? Contact us today!
Quicklinx: 92PDWS00 Mfr#: IES51000POE
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE
£163.96 ex VAT
£196.75 inc VAT
Connect Gigabit Ethernet and power to 4 PoE-enabled devices, with 15.4W per-port output. The IES51000POE 5-Port Gigabit PoE Switch with 4 PSE ports lets you connect Gigabit Ethernet and power to up to 4 PoE-enabled devices, or a mixture of PoE and non-PoE components.
Giving you the freedom to place your equipment in locations where power outlets are not available, this compact Power over Ethernet switch complies with IEEE 802.3af standards and supplies up to 15.4 W per port, with a total power budget of 62W. A true unmanaged switching solution, the 4 PSE (Power Sourcing Equipment) ports sense whether the connected devices are PoE-ready or require data connectivity only, while all 5 ports auto-negotiate between 10/100/1000 Mbps network speed and duplex.
The Gigabit Ethernet switch features a sturdy, wall-mountable metal enclosure for durability, and front panel LEDs for quick indication of connection speed and status.
StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 Power over Ethernet ports - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE) + 1 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
62 W
Power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x
AC 120/230 V
9 cm x 13 cm x 2.8 cm
366 g
North America, United Kingdom, Europe
Enclosure Type
Wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
62 W
1 x Realtek Semiconductor RTL8370
Status Indicators
Power, PoE, link/activity
4 x 100Base-TX RJ-45 PoE - 15.4 W , 1 x 100Base-TX RJ-45 uplink
External power adapter
AC 120/230 V
62 Watt
UL, FCC, RoHS
9 cm
13 cm
2.8 cm
366 g
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
Max Storage Temperature
50 °C
Humidity Range Storage
92PD StarTech.com 10 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.23
92PD StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet In Stock £101.45
Ports: 5
Managed: No
POE: PoE
Price Range Ex VAT: 150 - 300
