The DS51002 5-port unmanaged Gigabit Ethernet switch lets you network up to 5 Ethernet devices through an energy-efficient gigabit switch, designed for desktop or wallmount installations.
Compatible with 10/100/1000 Mbps networks, this 5 port switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation, allowing you to connect your network devices quickly and easily with little to no configuration required.
This unmanaged switch supports the IEEE 802.3az energy-efficient Ethernet standard, which offers power-saving features without compromising performance. The switch can automatically power down ports without a link, budget power output based on cable lengths and can also reduce the power consumption in idle or low-traffic modes.
- StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet Desktop / Wall Mount Network Switch - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Forwarding performance (full duplex): 2 Gbps
- Jumbo Frame Support
- 16KB
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V
- 18 cm x 12 cm x 3.01 cm
- 215 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- 16KB
- Status Indicators
- Power, link/activity
- 5 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- 18 cm
- 12 cm
- 3.01 cm
- 215 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
