StarTech.com 5 Port PCI Express USB 2.0 Adapter Card
Quicklinx: 4JF7WS00 Mfr#: PEX400USB2
  • Windows 8 (32/64 bits)
Add 4 external USB ports and 1 internal USB port to your computer through a PCI Express slot. This 5 Port PCI Express USB 2.0 adapter card lets you connect up to five USB 2.0 peripherals (4 external and 1 shared internal) to your computer, with support for high speed USB data transfer rates of up to 480 Mbps.
Plus, the PCI Express USB card is backward compatible with USB 1.1, so you can continue using your older USB peripherals.
Featuring easy plug and play installation, this adapter card provides convenient, hassle-free connections without having to reboot the host computer.
StarTech.com 5 Port PCI Express USB 2.0 Adapter Card - USB adapter - PCIe - 5 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports Qty
5 ports
USB, USB 2.0
Data Transfer Rate
480 Mbps
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
P/N: ICUSB2322I, ICUSB2328I
USB adapter - 5 ports
Plug-in card
PCI Express x1
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
4 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
Compatible Slots
1 x PCI Express x1
UL, FCC
Limited warranty - lifetime
