Network up to 5 Ethernet devices through a rugged, industrial Gigabit Ethernet switch - DIN / Wall Mountable. The IES51000 5-Port Industrial Ethernet Switch offers 5 Gigabit Ethernet ports in a compact, IP30-rated metal enclosure, making it the ideal network solution for harsh industrial environments such as factory floors, warehouses or large junction boxes.
Quickly connect your network devices with little to no configuration. This unmanaged industrial network switch supports 10/100/1000 Mbps transfer speeds, full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX, which helps to eliminate the hassle of troubleshooting mis-matched speed and duplex settings.
Providing seamless operation in the event of power dips or failures, the switch features redundant 12-58V DC terminal block power inputs to help prevent unnecessary downtime. When used with two power sources, the switch also supports alarm relay contacts that you can wire to your existing alarm circuit to notify you instantly when a power disruption occurs.
For easy installation and dependable performance in harsh environments, the switch can be DIN Rail or wall mounted and features a compact, IP30-rated enclosure with an extended operating temperature range (-40°C to 75°C).
- StarTech.com 5 Port Unmanaged Industrial Gigabit Ethernet Switch - DIN Rail / Wall-Mountable Network Switch - Rugged IP30 Gigabit Switch (IES51000) - switch - 5 ports
- Switch - 5 ports
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Forwarding performance (full duplex): 2 Gbps
- Jumbo Frame Support
- 9KB
- Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, wall mountable, QoS, 128KB packet buffer, LACP, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
- Power
- DC 12 -58 V
- 8.94 cm x 11.22 cm x 2.91 cm
- 329 g
- Black
- 2-year warranty
- Switch - 5 ports
- Enclosure Type
- Desktop, DIN rail mountable, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- 9KB
- Status Indicators
- Port transmission speed, power, alarm, link/activity
- 5 x 1000Base-T RJ-45 , 1 x 6 pin terminal block
- Power Device
- Internal power supply
- Voltage Required
- DC 12 -58 V
- 3.63 Watt
- Black
- Included Accessories
- Mounting brackets
- Rack Mounting Kit
- Included
- FCC, RoHS
- 8.94 cm
- 11.22 cm
- 2.91 cm
- 329 g
- Limited warranty - 2 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
StarTech.com 5 Port Industrial Gigabit Ethernet Switch | In Stock | £135.72 |
StarTech.com Unmanaged 2.5G Switch - 5 port | In Stock | £104.27 |
