The 5-Port Unmanaged Industrial Ethernet Switch from StarTech.com is designed for rugged environments, supporting a wide range of operating temperatures from -40°C to 75°C. With five 1000Base-T ports, this switch facilitates reliable connectivity for industrial applications requiring robust networking capabilities. The switch features a fanless design and is built with a metal housing, ensuring durability and longevity in harsh conditions. It is compliant with various standards including FCC, RoHS, and TAA, making it suitable for diverse deployment scenarios. Equipped with Wake On LAN (WOL), Automatic Media-Dependent Interface Crossover (MDIX), and a MAC Address Table Size of 9K entries, this switch ensures efficient data management and network performance. The status indicators for power and link/activity provide immediate feedback on the device’s operational status. Furthermore, its ability to be wall or DIN rail mounted adds versatility to installation options, making it an ideal choice for industries needing reliable Ethernet solutions.
Rugged design
This switch is built with a metal housing that withstands harsh industrial conditions, ensuring long-term reliability. -
Temperature resilience
Operating effectively in extreme temperatures from -40°C to 75°C, this switch is ideal for demanding environments. -
Versatile installation options
Capable of being wall or DIN rail mounted, this switch offers flexibility for deployment in various industrial settings. -
High performance
Equipped with five 1000Base-T ports and a MAC Address Table Size of 9K entries, facilitating efficient network performance. -
User-friendly features
Includes automatic media-dependent interface crossover (MDIX) and Wake On LAN (WOL) for seamless connectivity and management.
 - StarTech.com 5-Port Unmanaged Industrial Ethernet Switch - IP30 - TAA - switch - 5 ports - unmanaged - TAA Compliant
 - Switch - 5 ports - unmanaged
- Subtype
 - Gigabit Ethernet
- Ports
 - 5 x 10/100/1000Base-T
- MAC Address Table Size
 - 9K entries
 - Security slot (Kensington security lock compatible), LED status indicator, WOL, Auto MDIX, full duplex mode, PXE support, store and forward, metal housing, fanless, rugged
 - IEEE 802.1p, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x
- Power
 - DC DC 9-60 V
 - 6 cm x 10 cm x 2.6 cm
 - 221.7 g
 - Black
- TAA Compliant
 - 2-year warranty
- Enclosure Type
 - DIN rail mountable, wall-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 9K entries
- Status Indicators
 - Power, link/activity
 - 5 x 1000Base-T RJ-45 , 1 x power input 3 pin terminal block
- Voltage Required
 - DC DC 9-60 V
 - Black
- Included Accessories
 - 3-pin terminal block, DIN-rail mounting kit, mounting ear kit
- MTBF
 - 556,710 hours
 - IP30, RoHS, MET, FCC, WEEE
- TAA Compliant
 - 6 cm
 - 10 cm
 - 2.6 cm
 - 221.7 g
- Shipping Width
 - 10.7 cm
- Shipping Depth
 - 15.9 cm
- Shipping Height
 - 5.5 cm
- Shipping Weight
 - 293.7 g
 - Limited warranty - 2 years
 - -40 °C
 - 75 °C
 - 0 - 95% RH (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 85 °C
