StarTech.com 5-Port Ethernet Switch - IP30
Quicklinx: J1LLWS00 Mfr#: I51G-ETHERNET-SWITCH
£67.56 ex VAT
£81.07 inc VAT
The 5-Port Unmanaged Industrial Ethernet Switch from StarTech.com is designed for rugged environments, supporting a wide range of operating temperatures from -40°C to 75°C. With five 1000Base-T ports, this switch facilitates reliable connectivity for industrial applications requiring robust networking capabilities. The switch features a fanless design and is built with a metal housing, ensuring durability and longevity in harsh conditions. It is compliant with various standards including FCC, RoHS, and TAA, making it suitable for diverse deployment scenarios. Equipped with Wake On LAN (WOL), Automatic Media-Dependent Interface Crossover (MDIX), and a MAC Address Table Size of 9K entries, this switch ensures efficient data management and network performance. The status indicators for power and link/activity provide immediate feedback on the device’s operational status. Furthermore, its ability to be wall or DIN rail mounted adds versatility to installation options, making it an ideal choice for industries needing reliable Ethernet solutions.
  • Rugged design
    This switch is built with a metal housing that withstands harsh industrial conditions, ensuring long-term reliability.
  • Temperature resilience
    Operating effectively in extreme temperatures from -40°C to 75°C, this switch is ideal for demanding environments.
  • Versatile installation options
    Capable of being wall or DIN rail mounted, this switch offers flexibility for deployment in various industrial settings.
  • High performance
    Equipped with five 1000Base-T ports and a MAC Address Table Size of 9K entries, facilitating efficient network performance.
  • User-friendly features
    Includes automatic media-dependent interface crossover (MDIX) and Wake On LAN (WOL) for seamless connectivity and management.
StarTech.com 5-Port Unmanaged Industrial Ethernet Switch - IP30 - TAA - switch - 5 ports - unmanaged - TAA Compliant
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000Base-T
9K entries
Security slot (Kensington security lock compatible), LED status indicator, WOL, Auto MDIX, full duplex mode, PXE support, store and forward, metal housing, fanless, rugged
IEEE 802.1p, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x
DC DC 9-60 V
6 cm x 10 cm x 2.6 cm
221.7 g
TAA Compliant
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
9K entries
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45 , 1 x power input 3 pin terminal block
DC DC 9-60 V
3-pin terminal block, DIN-rail mounting kit, mounting ear kit
MTBF
556,710 hours
IP30, RoHS, MET, FCC, WEEE
TAA Compliant
6 cm
10 cm
2.6 cm
221.7 g
Shipping Width
10.7 cm
Shipping Depth
15.9 cm
Shipping Height
5.5 cm
Shipping Weight
293.7 g
-40 °C
75 °C
0 - 95% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
