Brand
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable
Quicklinx: FB6HWS00 Mfr#: CDP2DP146B
Interface: USB-C
More than 50 in stock
£28.09 ex VAT
£33.70 inc VAT
This USB-C to DisplayPort adapter cable lets you connect your USB Type-C device to a DisplayPort monitor with just one cable, providing you with a convenient, clutter-free solution.
Supporting four times the resolution of 4K, this8K DP 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography.
The DP adapter is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
At 5.9 ft. (1.8 m) in length, this adapter delivers a direct connection that eliminates excess cabling, ensuring a tidy installation. For installations requiring a shorter length, a 3.3 ft. (1 m) (CDP2DP141MB) DisplayPort cable enables you to customize your connection needs.
To ensure easy operation, this DP adapter supports plug-and-play installation, removing the need for additional software or drivers.
Note: Your USB-C device must support DP Alt Mode to work with this adapter.
StarTech.com 6ft/1.8m USB C to DisplayPort 1.4 Cable, 4K/5K/8K USB Type-C to DP 1.4 Alt Mode Video Adapter Converter, HBR3/HDR/DSC, 8K 60Hz DP 1.4 Monitor Cable for USB-C and Thunderbolt 3 - 8K USB-C to DP Cable - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
7680 x 4320
DisplayPort (male connector)
Length
1.8 m
Enclosure Colour
3-year warranty
P/N: TB4CDOCK
Bus Type
USB-C
Max Resolution
7680 x 4320 at 60 Hz
DisplayPort Alternate Mode, Thunderbolt 3 compatible, 8K Display Support, HBR3 support
DisplayPort 1.4
Length
1.8 m
Enclosure Colour
Limited warranty - 3 years
P/N: TB4CDOCK
FB6H StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £13.19
FB6H StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £23.57
FB6H StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £14.55
FB6H StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £29.50
FB6H StarTech.com 6ft USB-C to DisplayPort Cable In Stock £27.72
FB6H StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £58.56
FB6H StarTech.com USB-C to DisplayPort Adapter In Stock £22.02
FB6H StarTech.com USB-C to DisplayPort Adapter In Stock £22.54
FB6H StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £28.09
FB6H StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £26.91
FB6H StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £17.27
FB6H StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £29.12
Interface: USB-C
