StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable
Quicklinx: FB6HWS00 Mfr#: CDP2DP146B
Length: 1.8m
Hurry, only 1 left in stock!
£18.05 ex VAT
£21.66 inc VAT
This USB-C to DisplayPort adapter cable lets you connect your USB Type-C device to a DisplayPort monitor with just one cable, providing you with a convenient, clutter-free solution.
Supporting four times the resolution of 4K, this8K DP 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography.
The DP adapter is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
At 5.9 ft. (1.8 m) in length, this adapter delivers a direct connection that eliminates excess cabling, ensuring a tidy installation. For installations requiring a shorter length, a 3.3 ft. (1 m) (CDP2DP141MB) DisplayPort cable enables you to customize your connection needs.
To ensure easy operation, this DP adapter supports plug-and-play installation, removing the need for additional software or drivers.
Note: Your USB-C device must support DP Alt Mode to work with this adapter.
  • High-resolution support
    This cable accommodates video output up to 7680 x 4320, allowing for detail and clarity in visuals.
  • Smooth video performance
    With a V-Sync rate of 60 Hz at maximum resolution, this cable ensures playback for an enhanced viewing experience.
  • Broad compatibility
    Designed to support Thunderbolt 3, this cable offers flexibility for use with a variety of devices and configurations.
  • Advanced features
    It includes HBR3 support, ensuring the highest bandwidth and performance for demanding applications.
  • Secure connection
    The male DisplayPort connector provides a reliable and stable connection, minimizing the risk of signal loss.
StarTech.com 6ft/1.8m USB C to DisplayPort 1.4 Cable, 4K/5K/8K USB Type-C to DP 1.4 Alt Mode Video Adapter Converter, HBR3/HDR/DSC, 8K 60Hz DP 1.4 Monitor Cable for USB-C and Thunderbolt 3 - 8K USB-C to DP Cable - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
7680 x 4320
Interfaces Details
DisplayPort (male connector)
Length
1.8 m
Enclosure Colour
3-year warranty
P/N: TB4CDOCK
Bus Type
USB-C
Max Resolution
7680 x 4320 at 60 Hz
Interfaces Details
8K Display Support, Thunderbolt 3 compatible, DisplayPort Alternate Mode, HBR3 support
DisplayPort 1.4
Length
1.8 m
Enclosure Colour
Limited warranty - 3 years
P/N: TB4CDOCK
FB6H StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.07
FB6H StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £11.69
FB6H StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £14.86
FB6H StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £13.10
FB6H StarTech.com 6ft USB-C to DisplayPort Cable In Stock £23.07
FB6H StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £40.20
FB6H StarTech.com USB-C to DisplayPort Adapter In Stock £22.55
FB6H StarTech.com USB-C to DisplayPort Adapter In Stock £20.76
FB6H StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.05
FB6H StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £24.08
FB6H StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £19.65
FB6H StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £31.40
Length: 1.8m
