Hot-swap any 3.5in SATA hard drive easily from any computer with a 5.25in bay.
This 3.5in SATA hard drive hot-swap bay allows you to install a 3.5in SATA drive (SATA, SATA II, SATA III-6Gbps) in an available/unused 5.25in drive bay. To remove the drive, it's as simple as opening the front panel door; to re-insert a drive, simply insert the drive (connector first) until the door closes.
The hot swap bay offers a trayless design that makes it the ideal solution for quick and easy drive removals and insertions as part of a system building process, or integration into rackmount systems or industrial environments.
Also a perfect addition for operating system image deployment and any task that requires being able to quickly access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
With support for SATA HDD speeds up to 6.0 Gbps, the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
Designed to provide a durable and reliable operating experience, the mobile rack features a 50,000+ insertion rating.
What's in the Box
- 1 - 5.25" Tray-Less SATA Hot-Swap Bay
- 2 - Key
- 1 - Screw Kit
- 1 - Instruction Manual
- StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive - Internal SATA Backplane Enclosure - Lockable drive bay (HSB100SATBK) - storage mobile rack
- Storage mobile rack
- Black
- Expansion Bays
- 1 x internal - 3.5"
- Compatible Bay
- 1 5.25" x 1/2H
- Hard Drive Form Factor Compatibility
- 3.5"
- Supported Interface
- SATA-600
- Drive Connector
- 7 pin Serial ATA
- Bay Connector
- 7 pin Serial ATA
- Key lock, hot-swappable drive carrier
- 14.9 cm x 18.4 cm x 4.2 cm
- 305 g
- 2-year warranty
- Designed For
- P/N: 25SAT35HDD, 25SATSAS35HD
- 3.5"
- Black
- SATA-600
Storage Controller
- Processor
- No CPU
- Bays
- 1 x SATA 6Gb/s - SATA
- Connections
- 1 x SATA 6Gb/s - 7 pin Serial ATA
- Compatible Bay
- 1 x external 5.25" x 1/2H
- FCC, RoHS
- Limited warranty - 2 years
- 14.9 cm
- 18.4 cm
- 4.2 cm
- 305 g
- 0 °C
- 50 °C
- 5 - 85%
- Designed For
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.46 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.40 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £43.89 |
StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot | In Stock | £25.89 |
StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £75.59 |
StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £89.85 |
StarTech.com 5.25 to 3.5 Drive Hot Swap Bay | In Stock | £33.35 |
