StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive
Quicklinx: 4RY4WS00 Mfr#: HSB100SATBK
Type: Storage mobile rack
HD Size: 3.5
Power Supply: None
43 In Stock
£17.75 ex VAT
£21.30 inc VAT
Hot-swap any 3.5in SATA hard drive easily from any computer with a 5.25in bay.
This 3.5in SATA hard drive hot-swap bay allows you to install a 3.5in SATA drive (SATA, SATA II, SATA III-6Gbps) in an available/unused 5.25in drive bay. To remove the drive, it's as simple as opening the front panel door; to re-insert a drive, simply insert the drive (connector first) until the door closes.
The hot swap bay offers a trayless design that makes it the ideal solution for quick and easy drive removals and insertions as part of a system building process, or integration into rackmount systems or industrial environments.
Also a perfect addition for operating system image deployment and any task that requires being able to quickly access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
With support for SATA HDD speeds up to 6.0 Gbps, the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
Designed to provide a durable and reliable operating experience, the mobile rack features a 50,000+ insertion rating.
What's in the Box - 1 - 5.25" Tray-Less SATA Hot-Swap Bay
- 2 - Key
- 1 - Screw Kit
- 1 - Instruction Manual
  • Secure locking mechanism
    The integrated key lock feature ensures that drives are securely housed, preventing unauthorized access and keeping data safe.
  • Efficient drive swapping
    With its hot-swappable design, the mobile rack allows users to swap drives quickly without powering down the system, enhancing workflow efficiency.
  • Versatile compatibility
    This mobile rack is designed for 3.5-in hard drives, providing flexibility and ease for users needing to expand their storage solutions.
  • Durable environmental standards
    Constructed to function within a wide temperature range of 0°C to 50°C and humidity from 5 to 85%, ensuring reliability in diverse settings.
  • Simple installation
    The 5.25-in form factor allows for easy integration into existing setups, making it a practical choice for both novice and experienced users.
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive - Internal SATA Backplane Enclosure - Lockable drive bay (HSB100SATBK) - storage mobile rack
Storage mobile rack
Expansion Bays
1 x internal - 3.5"
Compatible Bay
1 5.25" x 1/2H
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA-600
Drive Connector
7 pin Serial ATA
Bay Connector
7 pin Serial ATA
Key lock, hot-swappable drive carrier
14.9 cm x 18.4 cm x 4.2 cm
305 g
P/N: 25SAT35HDD, 25SATSAS35HD
Storage mobile rack
3.5"
Supported Interface
SATA-600
Storage Controller
No CPU
Bays
1 x internal - 3.5"
1 x SATA 6Gb/s - SATA
1 x SATA 6Gb/s - 7 pin Serial ATA
Compatible Bay
1 x external 5.25" x 1/2H
FCC, RoHS
14.9 cm
18.4 cm
4.2 cm
305 g
50 °C
5 - 85%
4RY4 StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.78
4RY4 StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.75
4RY4 StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £44.84
4RY4 StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £26.41
4RY4 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £69.01
4RY4 StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £84.20
4RY4 StarTech.com 5.25 to 3.5 Drive Hot Swap Bay In Stock £29.81
HD Size: 3.5
Power Supply: None
