StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio
Quicklinx: 5JS9WS00 Mfr#: ST424MX
Hurry, only 1 left in stock!
£203.98 ex VAT
£244.77 inc VAT
Share up to four distinct VGA inputs and audio source signals between multiple monitors. The ST424MX 4x4 VGA Matrix Switcher/Splitter allows users to share up to four distinct VGA inputs (as well as corresponding audio source) between four independent displays or projectors.
Providing convenient push button control, the VGA Matrix Switcher/Splitter allows each of the four input VGA signals and the corresponding audio, to be switched individually meaning that you can have a different source showing on each display or one source showing on both offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management even over longer distance signal transmissions, the ST424MX VGA Matrix Switcher/Splitter features a built-in signal booster that facilitates installation of displays at distances of up to 210ft away from the source device, while maintaining flawless signal integrity.
Designed to provide maximum control while saving space and eliminating clutter, the ST424MX can be used as a standalone solution or rack mounted using the (included) ear-mounts.
StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
VGA / audio
26.9 cm x 10.4 cm x 4.2 cm
1.1 kg
Enclosure Type
Desktop
Subtype
VGA / audio
Max Resolution
1920 x 1440
Max Video Bandwidth
350 MHz
4 x VGA HD-15 , 4 x audio mini-jack , 4 x VGA HD-15 , 4 x audio mini-jack
External power adapter
Rack Mounting Kit
Included
FCC, RoHS
26.9 cm
10.4 cm
4.2 cm
1.1 kg
5JS9 StarTech.com 50 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £34.12
5JS9 StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £17.08
5JS9 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.74
5JS9 StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.55
Price Range Ex VAT: 150 - 300
