Share up to four distinct VGA inputs and audio source signals between multiple monitors. The ST424MX 4x4 VGA Matrix Switcher/Splitter allows users to share up to four distinct VGA inputs (as well as corresponding audio source) between four independent displays or projectors.
Providing convenient push button control, the VGA Matrix Switcher/Splitter allows each of the four input VGA signals and the corresponding audio, to be switched individually meaning that you can have a different source showing on each display or one source showing on both offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management even over longer distance signal transmissions, the ST424MX VGA Matrix Switcher/Splitter features a built-in signal booster that facilitates installation of displays at distances of up to 210ft away from the source device, while maintaining flawless signal integrity.
Designed to provide maximum control while saving space and eliminating clutter, the ST424MX can be used as a standalone solution or rack mounted using the (included) ear-mounts.
- StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio - 4x4 VGA Matrix - VGA Video Switcher - Video matrix Switch (ST424MX) - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- VGA / audio
- 26.9 cm x 10.4 cm x 4.2 cm
- 1.1 kg
- Black
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- VGA / audio
- Max Resolution
- 1920 x 1440
- Max Video Bandwidth
- 350 MHz
- 4 x VGA HD-15 , 4 x audio mini-jack , 4 x VGA HD-15 , 4 x audio mini-jack
- Power Device
- External power adapter
- Black
- Rack Mounting Kit
- Included
- FCC, RoHS
- 26.9 cm
- 10.4 cm
- 4.2 cm
- 1.1 kg
- Limited warranty - 2 years
- Designed For
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
