StarTech.com 4x4 HDMI Matrix Video Switch Splitter with Audio and RS232
Quicklinx: 7P4KWS00 Mfr#: VS440HDMI
£206.95 ex VAT
£248.34 inc VAT
The VS440HDMI 4x4 HDMI Audio/Video Matrix Switch/Splitter (with Audio and RS232) lets you share up to 4 distinct HDMI or DVI inputs (using HDMI to DVI adapters - not included), with audio, between 4 independent displays or projectors.
Providing convenient front push-button and RS232 PC software control, this matrix switch allows each input and the corresponding audio to be switched individually, meaning that different A/V sources can be shown on each output, or a single source can be output to several offering maximum flexibility.
The switcher features a front panel LCD display for easy status monitoring, plus an included remote control and IR extender module for simple control from a distance.
Designed to provide maximum functionality while saving space, the HDMI Video Matrix Switch can be used as a standalone solution or rack-mounted using ear-mounts (included).
StarTech.com 4x4 HDMI Matrix Video Switch Splitter with Audio and RS232 - 4x1 HDMI Video Switch - 4 Port HDMI Switcher (VS440HDMI) - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
AC 120/230 V
18.5 cm x 44 cm x 4.2 cm
2.4 kg
1-year warranty
P/N: ST121HDBT20L, ST121HDBT20S, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121SHD50, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
HDMI
Max Resolution
1080p
Max Video Bandwidth
225 MHz
4 x HDMI input , 4 x HDMI output , 1 x serial (RS-232) DB-9
External power adapter
AC 120/230 V
Rack Mounting Kit
Included
FCC, RoHS
18.5 cm
44 cm
4.2 cm
2.4 kg
Limited warranty - 1 year
70 °C
0 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
7P4K StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
7P4K StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
7P4K StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
7P4K StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p In Stock £57.28
7P4K StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p In Stock £83.51
7P4K StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall In Stock £624.24
7P4K StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
7P4K StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
7P4K StarTech.com 4x4 HDMI Matrix Switch w/Audio In Stock £492.93
