StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall
Quicklinx: 9TVDWS00 Mfr#: VS424HDPIP
£624.24 ex VAT
£749.08 inc VAT
Share and switch four distinct HDMI audio/video sources between four HDMI displays, with optional Picture-and-Picture. The VS424HDPIP 4X4 HDMI Matrix Switch with Picture-and-Picture (PAP) gives you the power to seamlessly combine and distribute four HDMI audio/video sources across four different HDMI displays, with the added ability to combine multiple images on the same display.
The split-screen multiplexing switch combines the flexibility of a matrix switch with the scalability of a video wall, giving you the freedom to combine video sources on a single display. You can also distribute different video combinations independently across four individual displays. The switch offers full matrix configuration supporting four different picture-and-picture modes per display: Matrix Mode (1x1) / Dual Mode (2x1) / Quad Mode (4x1) / TV Wall Mode (1x4).
Fitting your boardroom or digital signage application with a VS424HDPIP dramatically increases your communication possibilities. Not only does the picture-and-picture matrix switch increase your communication by a factor of four per display, but it also enables you to adjust your video sources remotely using RS232 serial, your local TCP/IP network, or the included IR remote control.
The VS424HDPIP is a flexible video switch that can improve any video display application. The picture-and-picture technology enables you to share up to four distinct images on the same screen, reducing required video real estate and saving you from wasting money on additional displays in your digital signage applications. For security monitoring, you can combine four video sources onto a single display to view everything more efficiently and broadcast those feeds to four different displays in different locations - you can even zoom into to a single feed for a closer look without disrupting the remaining three displays. For versatile installation options, mounting hardware is included ensuring a tidy and professional installation.
  • Versatile connectivity
    The 4x4 HDMI Matrix Switch features four HDMI inputs and outputs, allowing users to connect multiple sources and output them to different displays easily.
  • High-definition support
    This matrix switch supports a maximum video resolution of 1080p, ensuring crisp and clear visuals for various applications.
  • Compact design
    Designed as a desktop unit, this switch fits seamlessly into any setup, whether for professional or personal use.
  • Reliable power supply
    An external power adapter provides a nominal voltage of AC 120/230 V, ensuring the switch operates efficiently across different regions.
  • Compliance assurance
    Meeting FCC and RoHS standards, this matrix switch ensures safe and environmentally friendly operation for users.
StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall - 4x4 Matrix Switch with Video Combining (VS424HDPIP) - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
AC 120/230 V
P/N: SVA12M5NA
Enclosure Type
Desktop
Subtype
HDMI
Max Resolution
1080p
4 x HDMI input , 4 x HDMI output
External power adapter
AC 120/230 V
Remote control
FCC, RoHS
P/N: SVA12M5NA
9TVD StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
9TVD StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.68
9TVD StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
9TVD StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £14.74
9TVD StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p In Stock £83.51
9TVD StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall In Stock £624.24
9TVD StarTech.com 4-Port 4K HDMI Video Switch In Stock £117.90
9TVD StarTech.com 2-Port 4K HDMI Video Switch In Stock £88.44
9TVD StarTech.com 2x2 HDMI Matrix Switch - 4K In Stock £140.50
9TVD StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
9TVD StarTech.com 4x4 HDMI Matrix Switch w/Audio In Stock £492.93
Price Range Ex VAT: £500 - £750
