Share and switch four distinct HDMI audio/video sources between four HDMI displays, with optional Picture-and-Picture. The VS424HDPIP 4X4 HDMI Matrix Switch with Picture-and-Picture (PAP) gives you the power to seamlessly combine and distribute four HDMI audio/video sources across four different HDMI displays, with the added ability to combine multiple images on the same display.
The split-screen multiplexing switch combines the flexibility of a matrix switch with the scalability of a video wall, giving you the freedom to combine video sources on a single display. You can also distribute different video combinations independently across four individual displays. The switch offers full matrix configuration supporting four different picture-and-picture modes per display: Matrix Mode (1x1) / Dual Mode (2x1) / Quad Mode (4x1) / TV Wall Mode (1x4).
Fitting your boardroom or digital signage application with a VS424HDPIP dramatically increases your communication possibilities. Not only does the picture-and-picture matrix switch increase your communication by a factor of four per display, but it also enables you to adjust your video sources remotely using RS232 serial, your local TCP/IP network, or the included IR remote control.
The VS424HDPIP is a flexible video switch that can improve any video display application. The picture-and-picture technology enables you to share up to four distinct images on the same screen, reducing required video real estate and saving you from wasting money on additional displays in your digital signage applications. For security monitoring, you can combine four video sources onto a single display to view everything more efficiently and broadcast those feeds to four different displays in different locations - you can even zoom into to a single feed for a closer look without disrupting the remaining three displays. For versatile installation options, mounting hardware is included ensuring a tidy and professional installation.
- StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall - 4x4 Matrix Switch with Video Combining (VS424HDPIP) - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI
- Power
- AC 120/230 V
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Max Resolution
- 1080p
- 4 x HDMI input , 4 x HDMI output
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Included Accessories
- Remote control
- FCC, RoHS
- Limited warranty - 2 years
- Designed For
- P/N: SVA12M5NA
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.52 |
StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £11.60 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.66 |
StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £19.75 |
StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p | In Stock | £94.34 |
StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall | In Stock | £1,106.58 |
StarTech.com 4-Port 4K HDMI Video Switch | In Stock | £138.09 |
StarTech.com 2-Port 4K HDMI Video Switch | In Stock | £94.18 |
StarTech.com 2x2 HDMI Matrix Switch - 4K | In Stock | £138.09 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com 4x4 HDMI Matrix Switch w/Audio | In Stock | £558.19 |
