Add three extra SATA power outlets to your Power Supply. The PYO4SATA SATA power splitter cable (1-to-4) features a SATA male power connector that connects to a single computer power supply SATA connector, and breaks out into four SATA female power connectors.
The SATA power splitter cable overcomes the limit of the number of SATA drives that can be installed in the system, based on available PSU power connections, and eliminates the cost of having to upgrade the power supply to accommodate additional SATA drives.
- StarTech.com 15.7 in (400 mm) SATA Power Splitter Adapter Cable - M/F - 4x Serial ATA Power Cable Splitter (PYO4SATA) - power splitter - SATA power to SATA power - 40 cm
- Power splitter
- Length
- 40 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 4 x 15 pin Serial ATA power - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB2535SATBK, PEXUSB311AC3, S251BU31REM, SATBP125VP, SATSASBP425
- Power splitter
- American Wire Gauge (AWG)
- 18
- Length
- 40 cm
- Black
- Connector
- RoHS
- Designed For
StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F | In Stock | £4.29 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £6.62 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.78 |
StarTech.com 8in 15 pin SATA Power Extension Cable | In Stock | £5.80 |
StarTech.com 12in 15 pin SATA Power Extension Cable | In Stock | £8.36 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.30 |
