StarTech.com 4x SATA Power Splitter Adapter Cable
Quicklinx: 87PNWS00 Mfr#: PYO4SATA
Length: 40cm
40 In Stock
£6.36 ex VAT
£7.63 inc VAT
Add three extra SATA power outlets to your Power Supply. The PYO4SATA SATA power splitter cable (1-to-4) features a SATA male power connector that connects to a single computer power supply SATA connector, and breaks out into four SATA female power connectors.
The SATA power splitter cable overcomes the limit of the number of SATA drives that can be installed in the system, based on available PSU power connections, and eliminates the cost of having to upgrade the power supply to accommodate additional SATA drives.
StarTech.com 15.7 in (400 mm) SATA Power Splitter Adapter Cable - M/F - 4x Serial ATA Power Cable Splitter (PYO4SATA) - power splitter - SATA power to SATA power - 40 cm
Power splitter
Length
40 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
4 x 15 pin Serial ATA power - female
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB2535SATBK, PEXUSB311AC3, S251BU31REM, SATBP125VP, SATSASBP425
Power splitter
American Wire Gauge (AWG)
18
Length
40 cm
Connector
RoHS
87PN StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £4.29
87PN StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.62
87PN StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.78
87PN StarTech.com 8in 15 pin SATA Power Extension Cable In Stock £5.80
87PN StarTech.com 12in 15 pin SATA Power Extension Cable In Stock £8.36
87PN StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.30
Length: 40cm
