StarTech.com 4U 19" Fixed Wall Mount Vertical Rack, Patch Panel Bracket Wall Mount for Data/AV/IT/Computer, Vertical Mounting, 4U Rack for Cabinet and Server Room, 180lb (81.6kg) Capacity (RK419WALLV2)
Versatile Design
Mount the bracket into a wall featuring wood stud construction, where studs are spaced 16in (40.6cm) apart. The patch panel wall mount rack is perfect for SoHo (small office, home office) and other small footprint applications allowing you to vertically mount up to 180lb (81.6kg) of standard rack equipment into this 14-gauge steel bracket. The mounting holes are positioned 16in (40.6cm) apart, matching the standard for construction framework. -
Included Hardware
The vertical wall mount network rack conveniently includes 6x wood screws, 16x M5 square cage nuts, and 16x M5 screws to attach the rack to a wall and mount your equipment. The wall mount vertical rack is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 4U 19" Wall Mount Vertical Rack, Patch Panel Wall Mount Bracket for Data/AV/IT/Computer Equipment, 4U Rack for Cabinet or Server Room, Supports 180lb (81.6kg) - Mounting Hardware Included (RK419WALLV2) - patch panel bracket (vertical) - 4U
- Product Type
- Patch panel bracket (vertical)
- Placing / Mounting
- Wall mountable
- Package Content
- 6 wood screws, 16 M5 cage nuts, 16 M5 screws, quick start guide
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 4U
- Product Material
- 14 gauge steel
- 50.5 cm x 15.5 cm x 19.3 cm
- Square hole, open frame, L-shaped mounting rail profile, 2-post
- Limited lifetime warranty
- Product Type
- Wall mountable
- Product Material
- 14 gauge steel
- Package Content
- Rack Size
- 19"
- 4U
- 50.5 cm
- 15.5 cm
- 19.3 cm
- Shipping Dimensions (WxDxH) / Weight
- 53.2 cm x 17 cm x 21.6 cm
- Black
- Finish
- Powder coat
- Weight Limit
- 81.6 kg
- EIA-310-E, REACH, ECA-310-E, ISTA 6
- TAA Compliant
- Limited warranty: - lifetime , Technical support: assistance - lifetime
