Mount networking equipment and shallow rackmount devices with this 4U wall-mountable rack
The 4U 13.78in. (35cm) deep wall-mounting bracket for patch panels and network equipment, delivers a sturdy and dependable equipment storage option, allowing you to wall mount data/IT equipment up to ta total of 44lbs. (20kg). It's the perfect solution for areas where space is at a premium like small office/home office environments or spaces with limited server room because it doesn't take up any floor space.
Sturdy Construction & Easy Installation
The mounting bracket features an all-steel design and is suitable for mounting patch panels, or other slim 19in rack equipment to a wall, and to organize cabling or equipment in your network closet, wiring closet, back office or IDF. The sturdy steel construction is especially helpful for durability in harsh environments. The open frame wall rack's mounting holes are positioned 16in. apart, matching typical drywall construction framework to ensure simple and secure wall-stud anchoring.
Includes Hardware
Cage nuts and screws are included with the wall-mount bracket, to save you the hassle of sourcing separate mounting hardware. The bracket is ideal for mounting equipment 12" or less in depth to ensure there is room for cabling.
WALLMOUNT4 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
Cold-rolled steel construction
The wall mounting data rack features a solid steel design for ultimate durability and to ensure a safe and sturdy mounting solution. It installs onto 16" studs with mounting holes. -
Easy cable management
Built with efficiency in mind, the small wall mount patch panel bracket has rear cable routing access for easy cable organization in your network closet, server room, wiring closet, classroom.
- StarTech.com 4U Wall Mount Rack, 19" Wall Mount Network Rack, 13.78 inch Deep (Low Profile), Wall Mounting Patch Panel Bracket for Network Switches, IT Equipment, 44lb (20kg) Capacity - Network Equipment Rack (WALLMOUNT4) - network device mounting bracket - 4U - 19"
- Product Type
- Network device mounting bracket
- Placing / Mounting
- Wall mountable
- Product Material
- Cold-rolled steel
- Height (Rack Units)
- 4U
- Limited lifetime warranty
- Product Type
- Wall mountable
- Product Material
- Cold-rolled steel
- 4U
- Rack Size
- 19"
- Mounting Kit
- Included
- Weight Limit
- 20 kg
- Low-profile
- Limited warranty - lifetime
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.20 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £49.48 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.44 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £15.50 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £47.16 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £30.81 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.01 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £26.84 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
StarTech.com 2U Wall-Mount Bracket | In Stock | £32.50 |
