StarTech.com 4U Vented Panel with Hinge
Quicklinx: BGC5WS00 Mfr#: RKPNLHV4U
Select:
£29.33 ex VAT
£35.19 inc VAT
Improve the organization and appearance of your rack while maintaining airflow. You can improve the appearance and airflow of any standard 19-inch server rack, while still enjoying easy access to unused space, using this hinged 4U blanking panel.
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room.
The blanking panel features a vented design which enables unobstructed airflow through your rack. The panel helps to maximize airflow to ensure your equipment is running at an optimal temperature.
This solid rack-panel features a hinged design that enables you to open the panel for fast and easy server access. You can quickly open the panel, make your required adjustments, and when you're finished, simply close the panel to restore the professional appearance and order of your server room. This rack panel is reversible enabling you can install it on the left or the right side of your rack, for a versatile installation. This rack panel also comes complete with rack installation screws and nuts, giving you everything you need to ensure a hassle-free installation.
  • Professional look
  • Maximize airflow
  • Hassle-free access
StarTech.com 4U Hinged Blanking Panel - Vented Server Rack Panel - Tool-less Installation - TAA Compliant Filler Rack Panel (RKPNLHV4U) - rack blanking panel - 4U
Rack blanking panel
Package Content
2 screws (10-32), 2 nuts (10-32)
Rack Size
19"
Height (Rack Units)
4U
Product Material
Plastic, steel
48.3 cm x 1.5 cm x 17.7 cm
585 g
Vented
P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack blanking panel
Product Material
Plastic, steel
Package Content
Rack Size
19"
Height (Rack Units)
4U
48.3 cm
1.5 cm
17.7 cm
585 g
Vented
EIA-310-D, RoHS
Limited warranty: - 2 years
