StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs
Quicklinx: FP9PWS00 Mfr#: RK4OD
£26.77 ex VAT
£32.12 inc VAT
Free Standing Network Rack EIA-310 Weight Cap. 66 lbs. Lifetime Warranty. This open frame desktop rack provides 4U of storage space for mounting smaller A/V and IT equipment.
Save money with a low-cost mounting solution
With this 2 post data rack, you can mount equipment at a fraction of the cost of conventional racks. The floor standing rack is engineered to meet EIA-310 rack-mount standards and is constructed of solid steel, ensuring a sturdy and safe mounting solution for your mission-critical equipment.
Improve efficiency and accessibility in your office or server room
The 4u desktop rack features an open frame, free standing design that saves space with a small footprint. It gives you the ability to place rack-mount equipment on any surface in your office, such as your desk. This makes it easy to access your equipment on a frequent basis.
Hassle-free setup
The free standing network rack is easy to assemble and includes a pack of 16 M5 screws and cage nuts. If you're looking for a desktop mounting solution with more rack units, StarTech.com also offers 8U and 12U 2-post desktop computer racks.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The RK4OD is backed by a StarTech.com lifetime warranty and free technical support.
  • Improve efficiency and accessibility in your office or server room
    The desktop rack features an open frame, free standing design that saves space with a small footprint.
  • Hassle-free setup
    The free standing network rack is easy to assemble.
StarTech.com 4U 19" Desktop Open Frame Rack, 2 Post Free-Standing Network Rack Switch Depth for Patch Panel/Data/AV/IT/Communication/Studio/Computer Equipment 66lb Cap. w/ Cage Nuts/Screws - 4U 2-Post Desktop Rack (RK4OD) - rack - 4U
Rack
Rack Type
Open frame - 2-post
Placing / Mounting
Desktop
Package Content
4 rubber feet, left vertical rail, right vertical rail, front base bracket, left base bracket, right base bracket, 8 M5 x 12 assembly screws, 16 M5 x 16 screws, 16 M5 cage nuts
Height (Rack Units)
4U
Product Material
Steel
50 cm x 29.3 cm x 23.5 cm
2.35 kg
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Placing / Mounting
Desktop
Product Material
Steel
Package Content
Height (Rack Units)
4U
50 cm
29.3 cm
23.5 cm
2.35 kg
54.9 cm x 16 cm x 12.5 cm / 2.36 kg
Weight Limit
30 kg
EIA-310
Limited warranty: - lifetime
