Improve the organization and appearance of your server rack. You can improve the appearance and airflow of any standard 19-inch server rack while maintaining easy access to server equipment, using this hinged 4U blanking panel.
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room.
This solid rack-panel features a hinged design that enables you to open it for fast and easy access to your rack-mounted devices. You can quickly open the panel, make your required adjustments and when you're finished, simply close the panel to restore the professional appearance and order of your server room. The panel is reversible, which enables you to install it on the left or the right side of your rack, to best suit your needs. This rack panel also comes complete with rack installation screws and nuts, giving you everything you need to ensure a hassle-free installation.
The blanking panel offers a solid design that helps guide airflow down the back of your rack, rather than passing between occupied spaces. Improved airflow helps ensure your rack-mounted equipment is running at an optimal temperature.
Professional look
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room. -
Hassle-free access
This solid rack-panel features a hinged design that enables you to open it for fast and easy access to your rack-mounted devices. You can quickly open the panel, make your required adjustments and when you're finished, simply close the panel to restore the professional appearance and order of your server room. The panel is reversible, which enables you to install it on the left or the right side of your rack, to best suit your needs. This rack panel also comes complete with rack installation screws and nuts, giving you everything you need to ensure a hassle-free installation. -
Improve airflow
- StarTech.com 4U Hinged Rack Panel - Solid Blanking Panel for 19-inch Server Racks - Tool-less Filler Panel (RKPNLHS4U) - blank panel - 4U
- Product Type
- Blank panel
- Location
- Front
- Package Content
- 2 screws (10-32), 2 nuts (10-32)
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 4U
- Product Material
- Steel
- 46.8 cm x 2.2 cm x 17.8 cm
- 980 g
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Blank panel
- Location
- Front
- Product Material
- Steel
- Package Content
- Rack Size
- 19"
- 4U
- 46.8 cm
- 2.2 cm
- 17.8 cm
- 980 g
- Black
- EIA-310-D, RoHS
- Limited warranty: - 2 years
- Designed For
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.43 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.34 |
StarTech.com 6U Vented Panel with Hinge | In Stock | £36.19 |
StarTech.com 4U Vented Panel with Hinge | In Stock | £29.54 |
StarTech.com 1U Vented Server Rack Panel | In Stock | £13.14 |
