StarTech.com 4U Blank Panel with Hinge
Quicklinx: BGC4WS00 Mfr#: RKPNLHS4U
Select:
Improve the organization and appearance of your server rack. You can improve the appearance and airflow of any standard 19-inch server rack while maintaining easy access to server equipment, using this hinged 4U blanking panel.
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room.
This solid rack-panel features a hinged design that enables you to open it for fast and easy access to your rack-mounted devices. You can quickly open the panel, make your required adjustments and when you're finished, simply close the panel to restore the professional appearance and order of your server room. The panel is reversible, which enables you to install it on the left or the right side of your rack, to best suit your needs. This rack panel also comes complete with rack installation screws and nuts, giving you everything you need to ensure a hassle-free installation.
The blanking panel offers a solid design that helps guide airflow down the back of your rack, rather than passing between occupied spaces. Improved airflow helps ensure your rack-mounted equipment is running at an optimal temperature.
  • Professional look
  • Hassle-free access
  • Improve airflow
StarTech.com 4U Hinged Rack Panel - Solid Blanking Panel for 19-inch Server Racks - Tool-less Filler Panel (RKPNLHS4U) - blank panel - 4U
Blank panel
Location
Front
Package Content
2 screws (10-32), 2 nuts (10-32)
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
46.8 cm x 2.2 cm x 17.8 cm
980 g
P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Blank panel
Location
Front
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
4U
46.8 cm
2.2 cm
17.8 cm
980 g
EIA-310-D, RoHS
Limited warranty: - 2 years
BGC4 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.49
