Improve the organization and appearance of your rack in seconds, with a tool-less solid blanking panel
This 4U blanking panel helps improve the appearance and airflow of your EIA-310 compliant 19 in. server rack.
Professional Look
This solid blank rack panel creates a clean and professional look by covering empty rack spaces and visible cables, for a more organized server room.
Improve Airflow
When used to cover unused rack units, this 4RU panel can help to control airflow and in certain applications, control internal temperatures by reducing the recirculation of hot air within the rack, created when unused spaces are left uncovered.
RKPNL4U is backed by a 2-year StarTech.com warranty and free lifetime technical support.
Professional look
This solid blank rack panel creates a clean and professional look by covering empty rack spaces and visible cables, for a more organized server room. -
Improve airflow
- StarTech.com 4U Blank Panel for 19 inch Rack, Rack Mount Blanking Panel for Server/Network Racks & Cabinets, 4RU Rackmount Filler Panel/Spacer/Plates, Solid Panel, Cold-Rolled Steel, Black - 4U Blanking Panel (RKPNL4U) - rack blanking panel - 4U
- Product Type
- Rack blanking panel
- Package Content
- 4 M6 screws, 4 M6 cage nuts
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 4U
- Product Material
- Steel
- 17.7 cm x 48.2 cm x 1.5 cm
- 1 kg
- Solid
- 2-year warranty
- Product Type
- Product Material
- Steel
- Package Content
- Rack Size
- 19"
- 4U
- 17.7 cm
- 48.2 cm
- 1.5 cm
- 1 kg
- Shipping Dimensions (WxDxH) / Weight
- 18.2 cm x 48.5 cm x 2 cm / 1.1 kg
- Black
- Solid
- RoHS, EIA-310-D
- Limited warranty: - 2 years
