StarTech.com 4U Blank Panel for 19 inch Rack - Rack Mount Blanking Panel
Quicklinx: GB6FWS00 Mfr#: RKPNL4U
Hurry, only 3 left in stock!
£15.50 ex VAT
£18.60 inc VAT
Improve the organization and appearance of your rack in seconds, with a tool-less solid blanking panel
This 4U blanking panel helps improve the appearance and airflow of your EIA-310 compliant 19 in. server rack.
Professional Look
This solid blank rack panel creates a clean and professional look by covering empty rack spaces and visible cables, for a more organized server room.
Improve Airflow
When used to cover unused rack units, this 4RU panel can help to control airflow and in certain applications, control internal temperatures by reducing the recirculation of hot air within the rack, created when unused spaces are left uncovered.
RKPNL4U is backed by a 2-year StarTech.com warranty and free lifetime technical support.
  • Professional look
  • Improve airflow
StarTech.com 4U Blank Panel for 19 inch Rack, Rack Mount Blanking Panel for Server/Network Racks & Cabinets, 4RU Rackmount Filler Panel/Spacer/Plates, Solid Panel, Cold-Rolled Steel, Black - 4U Blanking Panel (RKPNL4U) - rack blanking panel - 4U
Rack blanking panel
Package Content
4 M6 screws, 4 M6 cage nuts
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
17.7 cm x 48.2 cm x 1.5 cm
1 kg
Solid
Rack blanking panel
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
4U
17.7 cm
48.2 cm
1.5 cm
1 kg
18.2 cm x 48.5 cm x 2 cm / 1.1 kg
Solid
RoHS, EIA-310-D
Limited warranty: - 2 years
