StarTech.com 4U 19in Steel Horizontal Wall Mountable Server Rack
Quicklinx: 7P1CWS00 Mfr#: RK419WALVO
U Height: 4U
Depth (mm): 50.5cm
Type: Wall Mount
Width (mm): 11.8cm
£150.05 ex VAT
£180.06 inc VAT
Vertically mount your server or networking equipment to a wall, in this low-profile cabinet. The RK419WALVO 4U 19-inch Steel Side Mount Rack is a Wall Mountable 4U solid steel rack, providing a robust solution for mounting your telecom, network or server equipment. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
This server rack can be mounted in a server room, office, or above a doorway in rooms lacking the floor space for a full-size rack, expanding your workspace and keeping your equipment easily accessible.
The rack is constructed to EIA-RS310 standards and allows equipment to be mounted vertically - non-rackmount equipment can be installed using the rack as a wall case.
The bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16-inches apart, matching standard construction stud measurements for easy installation.
StarTech.com 4U Vertical Wall-Mount Server Rack Enclosure - 18.9in deep - 2 Post - 61lb - 19in Low Profile Steel Network Equipment Cabinet (RK419WALVO) - rack - 4U
Rack
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
11.8 cm x 50.5 cm x 55.3 cm
10.8 kg
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
4U
11.8 cm
50.5 cm
55.3 cm
10.8 kg
Weight Limit
27.7 kg
Mounting Kit
Included
RoHS
Limited warranty: - lifetime
7P1C StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
7P1C StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £40.62
7P1C StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £54.83
7P1C StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7P1C StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
7P1C StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7P1C StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7P1C StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
7P1C StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
7P1C StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
7P1C StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
7P1C StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
7P1C StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
7P1C StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
7P1C StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
7P1C StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
7P1C StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
7P1C StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
7P1C StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
7P1C StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
7P1C StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
7P1C StarTech.com 19in Cable Management Panel In Stock £24.18
7P1C StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
U Height: 4U
Depth (mm): 50.5cm
Type: Wall Mount
Width (mm): 11.8cm
