StarTech.com 4U 19in Hinged Wall Mounting Bracket for Patch Panels
Quicklinx: 7B8FWS00 Mfr#: WALLMOUNTH4
Product Type: Wall mount bracket
Hurry, only 1 left in stock!
£27.51 ex VAT
£33.01 inc VAT
This 4U patch panel wall mount bracket is 4in deep and sturdily designed to provide a dependable solution for mounting a patch panel to a wall. The patch panel wall mount features a hinged design for easy access.
StarTech.com 4U Hinged Wall Mount Patch Panel Bracket - 6 inch Deep - 19" Patch Panel Swing Rack for Shallow Network Equipment- 33lbs (WALLMOUNTH4) - wall mount bracket - 4U - 19"
Wall mount bracket
49 cm x 10.5 cm x 18 cm
Product Material
Steel
Height (Rack Units)
4U
Wall mount bracket
Product Material
Steel
Height (Rack Units)
4U
49 cm
10.5 cm
18 cm
Rack Size
19"
7B8F StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.10
7B8F StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
7B8F StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £34.98
7B8F StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £39.99
7B8F StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £54.90
7B8F StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
7B8F StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.13
7B8F StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7B8F StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.63
7B8F StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
7B8F StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7B8F StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £56.10
7B8F StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £56.64
7B8F StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
7B8F StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
7B8F StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.15
7B8F StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
7B8F StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
7B8F StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
7B8F StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
7B8F StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
7B8F StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.86
7B8F StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
7B8F StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
7B8F StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
7B8F StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
7B8F StarTech.com 2-Post Desktop Rack - 8U In Stock £35.14
7B8F StarTech.com 18U Server Rack Enclosure In Stock £379.01
7B8F StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
7B8F StarTech.com 26U Server Rack Enclosure In Stock £475.05
7B8F StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
7B8F StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
7B8F StarTech.com 12U Server Rack Enclosure In Stock £338.60
7B8F StarTech.com 12U Server Rack Enclosure In Stock £283.26
7B8F StarTech.com 15U Server Rack Enclosure In Stock £320.92
7B8F StarTech.com 12U Server Rack Enclosure In Stock £385.18
7B8F StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
7B8F StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
