StarTech.com 4PT USB 3.0 Hub - Charge Port
Quicklinx: D2N0WS00 Mfr#: ST4300MINI
Type: Docking station
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
10 In Stock
£31.93 ex VAT
£38.31 inc VAT
Add four external USB 3.0 ports and phone charging capability to your laptop with this portable hub. This 4-port USB 3.0 hub turns a single USB port on your laptop into four USB-A ports and features a compact, USB-powered design that makes it perfect for travel. For devices that demand extra power, the hub also comes with an external power adapter.
With its compact and lightweight design, this 4-port USB hub is tailored for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connection options almost anywhere you need to. It's perfect for connecting common USB devices such as a mouse, keyboard, or flash drive, right when you need them.
You can install the versatile USB 3.0 hub virtually anywhere, because it takes up minimal space on a desk, and fits perfectly in hot-desk or BYOD environments.
This self-powered USB hub comes with an external power adapter to support power-hungry USB devices, such as larger external drives and enclosures, which require more power than USB power can provide on its own.
With the power adapter, you can also charge your smartphone on one of the available ports. Each USB-A port supports USB Battery Charging Specification 1.2. It's recommended to only charge one device at a time.
This USB 3.0 hub will work with a wide range of computers because it requires no additional software or drivers. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS, so it's multi-platform compatible.
  • Reliable performance
    With an MTBF of 40,103 hours, this hub is built for long-lasting use, ensuring reliable operation over time.
  • Extensive compatibility
    Meets USB Battery Charging Specification Rev. 1.2 and is compatible with USB 1.1, USB 2.0, and USB 3.0 standards.
  • Versatile temperature range
    Handles operating temperatures from 0°C to 70°C and supports storage temperatures from -50°C to 120°C.
  • User-friendly setup
    Features a Plug-and-Play design for seamless connectivity with minimal configuration required.
  • External power support
    Powered externally with a voltage input of AC 120/230 V for consistent power supply during use.
StarTech.com 4 Port USB 3.0 Hub SuperSpeed 5Gbps with Fast Charge Portable USB 3.1/USB 3.2 Gen 1 Type-A Laptop/Desktop Hub, USB Bus Power or Self Powered for High Performance, Mini/Compact - 15W of Shared Power (ST4300MINI) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V
4 cm x 9 cm x 1.5 cm
280 g
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
P/N: USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X VIA Labs VL812
4 x USB 3.0 Type A charging port
External power adapter
AC 120/230 V
MTBF
40,103 hours
Plug and Play, FCC, RoHS, USB Battery Charging Specification Rev. 1.2
4 cm
9 cm
1.5 cm
280 g
70 °C
Min Storage Temperature
-50 °C
Max Storage Temperature
120 °C
D2N0 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.69
D2N0 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.23
D2N0 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.81
D2N0 StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £20.20
D2N0 StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £21.75
D2N0 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.34
D2N0 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.59
D2N0 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £63.50
D2N0 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £25.15
D2N0 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
D2N0 StarTech.com 7 Port Compact USB 3.0 Hub In Stock £45.75
D2N0 StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.24
D2N0 StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £57.36
Speed: 5Gbps
Ports: 4
