StarTech.com 4pt Managed Industrial USB Hub
Quicklinx: HHY7WS00 Mfr#: 5G4AINDRM-USB-A-HUB
Type: USB Hub
Interface: USB 3.2
Speed: [N/A]
Ports: 4
Form Factor: DIN rail mountable
£126.12 ex VAT
£151.34 inc VAT
MANAGED USB HUB:USB Hub Administrator software works with the USB hub to enable/disable ports or all ports and reboot the Hub; Windows, macOS, Linux; Supports CLI commands for custom application creation.
ROBUST and RELIABLE: With metal housing, 15kV/8kV level 4 ESD air/contact protection, this rugged USB 3.2 Gen 1 5Gbps hub reliably connects 4 USB devices in harsh industrial environments.
POWER AND CHARGING: USB hub supports 7 to 48 volts DC; powered via terminal block connector with power adapter (part number: ITB20D3250); 3x USB-A ports capable of charging BC 1.2 (2.4A).
VERSATILE MOUNTING OPTIONS: This mountable USB hub installs securely on/under a desk, wall or DIN rail using the integrated mounting ears and DIN brackets included; 1.8 m USB 3.2 Gen 1 cable included.
CONNECTIVITY TOOLS: Includes Connectivity Tools application, enabling administrators to identify potentially malicious devices; TAA-compliant; Ideal for remote operations and device security.
  • Robust design
    The 4-Port Managed USB Hub is encased in a heavy-duty metal industrial housing, designed to withstand harsh environments and demanding industrial applications. Its durability ensures reliable performance and longevity.
  • Advanced protection
    Equipped with ESD (Electrostatic Discharge) and surge protection, this USB hub safeguards connected devices against electrical spikes and static electricity, providing peace of mind in any setup.
  • Versatile connectivity
    Featuring 4x USB-A ports with support for USB 3.0/3.1/3.2 Gen 1 at 5 Gbps, the hub offers fast data transfer rates and is backward compatible with older USB standards, ensuring wide-ranging device compatibility.
  • Flexible installation
    Wall, desk, and Din-Rail mountable options offer flexibility in installation, making it an ideal choice for various setups, from office environments to industrial applications.
  • Efficient management
    With command-line interface (CLI) management, this hub allows for efficient setup and configuration, enhancing usability and control over connected devices.
StarTech.com 4-Port Managed USB Hub with 4x USB-A, Heavy Duty with Metal Industrial Housing, ESD & Surge Protection, Wall/Desk/Din-Rail Mountable, USB 3.0/3.1/3.2 Gen 1 5Gbps - hub - 4 ports - TAA Compliant
Hub - 4 ports
Subtype
USB
Ports
3 x USB 3.2 Gen 2 + 1 x USB 3.2 Gen 1
Surge protection, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), managed, fast charging support, CLI management, lockable ports
USB 1.1, USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1, Battery Charging 1.2
11.4 cm x 6.7 cm x 2.6 cm
TAA Compliant
Hub - 4 ports
Enclosure Type
Desktop, DIN rail mountable, wall-mountable
Subtype
USB
Ports
Status Indicators
Port status, power
3 x USB 3.2 Gen 2 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B host , 1 x terminal block
DIN-rail mounting kit, terminal block connector
1 x USB-A to USB-B cable - 1.8 m
MTBF
131,406 hours
RoHS, WEEE, UASP (USB Attached SCSI Protocol)
TAA Compliant
11.4 cm
6.7 cm
2.6 cm
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
450 g
60 °C
5 - 95% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
75 °C
HHY7 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.08
HHY7 StarTech.com 7pt Managed Industrial USB Hub In Stock £151.36
Type: USB Hub
Interface: USB 3.2
Speed: [N/A]
Ports: 4
