MANAGED USB HUB:USB Hub Administrator software works with the USB hub to enable/disable ports or all ports and reboot the Hub; Windows, macOS, Linux; Supports CLI commands for custom application creation.
ROBUST and RELIABLE: With metal housing, 15kV/8kV level 4 ESD air/contact protection, this rugged USB 3.2 Gen 1 5Gbps hub reliably connects 4 USB devices in harsh industrial environments.
POWER AND CHARGING: USB hub supports 7 to 48 volts DC; powered via terminal block connector with power adapter (part number: ITB20D3250); 3x USB-A ports capable of charging BC 1.2 (2.4A).
VERSATILE MOUNTING OPTIONS: This mountable USB hub installs securely on/under a desk, wall or DIN rail using the integrated mounting ears and DIN brackets included; 1.8 m USB 3.2 Gen 1 cable included.
CONNECTIVITY TOOLS: Includes Connectivity Tools application, enabling administrators to identify potentially malicious devices; TAA-compliant; Ideal for remote operations and device security.
Robust design
The 4-Port Managed USB Hub is encased in a heavy-duty metal industrial housing, designed to withstand harsh environments and demanding industrial applications. Its durability ensures reliable performance and longevity. -
Advanced protection
Equipped with ESD (Electrostatic Discharge) and surge protection, this USB hub safeguards connected devices against electrical spikes and static electricity, providing peace of mind in any setup. -
Versatile connectivity
Featuring 4x USB-A ports with support for USB 3.0/3.1/3.2 Gen 1 at 5 Gbps, the hub offers fast data transfer rates and is backward compatible with older USB standards, ensuring wide-ranging device compatibility. -
Flexible installation
Wall, desk, and Din-Rail mountable options offer flexibility in installation, making it an ideal choice for various setups, from office environments to industrial applications. -
Efficient management
With command-line interface (CLI) management, this hub allows for efficient setup and configuration, enhancing usability and control over connected devices.
- StarTech.com 4-Port Managed USB Hub with 4x USB-A, Heavy Duty with Metal Industrial Housing, ESD & Surge Protection, Wall/Desk/Din-Rail Mountable, USB 3.0/3.1/3.2 Gen 1 5Gbps - hub - 4 ports - TAA Compliant
- Hub - 4 ports
- Subtype
- USB
- Ports
- 3 x USB 3.2 Gen 2 + 1 x USB 3.2 Gen 1
- Surge protection, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), managed, fast charging support, CLI management, lockable ports
- USB 1.1, USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1, Battery Charging 1.2
- 11.4 cm x 6.7 cm x 2.6 cm
- Black
- TAA Compliant
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop, DIN rail mountable, wall-mountable
- Subtype
- USB
- Ports
- Status Indicators
- Port status, power
- 3 x USB 3.2 Gen 2 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B host , 1 x terminal block
- Black
- Included Accessories
- DIN-rail mounting kit, terminal block connector
- Cables Included
- 1 x USB-A to USB-B cable - 1.8 m
- MTBF
- 131,406 hours
- RoHS, WEEE, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- 11.4 cm
- 6.7 cm
- 2.6 cm
- Shipping Width
- 21.3 cm
- Shipping Depth
- 14.9 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 450 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 95% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 75 °C
