StarTech.com 4PT Dual DP KVM Switch 4K60
Quicklinx: DHP0WS00 Mfr#: SV431DPDDUA2
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
Hurry, only 3 left in stock!
£599.68 ex VAT
£719.61 inc VAT
This 4-port Dual DP KVM switch combines dual 4K 60Hz displays with KVM switch control of four connected PC and MAC computers. This 4-port dual DP KVM switch combines dual 4K 60Hz displays with KVM switch control of four connected PC and Mac computers. It features audio and USB peripheral support along with dual-display capability, which makes it easy to create a multimedia workstation that can switch between two dual-head DP systems.
With two DP video inputs and control of four different computers, this Ultra HD KVM switch helps maximize productivity by giving you the freedom to multitask. Each of the DP ports supports resolutions up to 4K 60Hz, for maximum screen viewing space.
The dual DisplayPort KVM switch supports resolutions up to 4K at 60Hz, and can drive two large DP displays with ease. An ideal solution for creating workstations where high-quality imaging is critical, such as for graphic design.
The KVM switch features full multimedia control with separate 3.5 mm microphone and speaker ports and two USB ports separate from the HID keyboard and mouse. The independent audio support lets you share independent analog audio from each of your connected computers, while the 2-port USB hub enables you to share USB peripherals between each connected computer.
StarTech.com DisplayPort KVM - 4 port - 4K 60Hz - Dual Monitor KVM - DisplayPort Switch - KVM DisplayPort - Desktop KVM Switch (SV431DPDDUA2) - KVM / audio / USB switch - 4 ports - rack-mountable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
AC 120/230 V
21.59 cm x 12.7 cm x 6.35 cm
1.2 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Enclosure Type
Desktop, rack-mountable
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Port status, power
2 x DisplayPort output , 1 x audio output mini-jack , 1 x microphone output mini-jack , 2 x USB 2.0 Type A , 2 x keyboard (USB) / mouse (USB) Type A , 4 x USB 2.0 input Type B , 8 x DisplayPort input , 4 x audio input mini-jack , 4 x microphone input mini-jack
External power adapter
Power Provided
DC 12 V - 1.5 A
AC 120/230 V
18 Watt
4 rubber feet
FCC, RoHS
21.59 cm
12.7 cm
6.35 cm
1.2 kg
0 - 80%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
DHP0 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
DHP0 StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £253.13
DHP0 StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.57
DHP0 StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £191.45
DHP0 StarTech.com DisplayPort USB KVM Switch In Stock £287.60
DHP0 StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £23.39
DHP0 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.05
DHP0 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
DHP0 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.26
DHP0 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
DHP0 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.63
DHP0 StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
DHP0 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
DHP0 StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £599.68
DHP0 StarTech.com 2 Pt DisplayPort KVM In Stock £302.73
DHP0 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
DHP0 StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £95.09
DHP0 StarTech.com 2-Port Dual-Monitor KVM Switch In Stock £314.68
DHP0 StarTech.com 4-Port Dual-Monitor KVM Switch In Stock £661.51
Connectivity: KVM
Ports: 4
Price Range Ex VAT: £500 - £750
