This 4-port Dual DP KVM switch combines dual 4K 60Hz displays with KVM switch control of four connected PC and MAC computers. This 4-port dual DP KVM switch combines dual 4K 60Hz displays with KVM switch control of four connected PC and Mac computers. It features audio and USB peripheral support along with dual-display capability, which makes it easy to create a multimedia workstation that can switch between two dual-head DP systems.
With two DP video inputs and control of four different computers, this Ultra HD KVM switch helps maximize productivity by giving you the freedom to multitask. Each of the DP ports supports resolutions up to 4K 60Hz, for maximum screen viewing space.
The dual DisplayPort KVM switch supports resolutions up to 4K at 60Hz, and can drive two large DP displays with ease. An ideal solution for creating workstations where high-quality imaging is critical, such as for graphic design.
The KVM switch features full multimedia control with separate 3.5 mm microphone and speaker ports and two USB ports separate from the HID keyboard and mouse. The independent audio support lets you share independent analog audio from each of your connected computers, while the 2-port USB hub enables you to share USB peripherals between each connected computer.
- StarTech.com DisplayPort KVM - 4 port - 4K 60Hz - Dual Monitor KVM - DisplayPort Switch - KVM DisplayPort - Desktop KVM Switch (SV431DPDDUA2) - KVM / audio / USB switch - 4 ports - rack-mountable
- Enclosure Type
- Rack-mountable
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 21.59 cm x 12.7 cm x 6.35 cm
- 1.2 kg
- Black
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Port status, power
- 2 x DisplayPort output , 1 x audio output mini-jack , 1 x microphone output mini-jack , 2 x USB 2.0 Type A , 2 x keyboard (USB) / mouse (USB) Type A , 4 x USB 2.0 input Type B , 8 x DisplayPort input , 4 x audio input mini-jack , 4 x microphone input mini-jack
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 1.5 A
- Voltage Required
- AC 120/230 V
- 18 Watt
- Black
- Included Accessories
- 4 rubber feet
- FCC, RoHS
- Localisation
- 21.59 cm
- 12.7 cm
- 6.35 cm
- 1.2 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.27 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £253.13 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.57 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £191.45 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £23.39 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.06 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.99 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.26 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.79 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.63 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.96 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com 4PT Dual DP KVM Switch 4K60 | In Stock | £599.68 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £302.73 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.12 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £95.09 |
StarTech.com 2-Port Dual-Monitor KVM Switch | In Stock | £314.68 |
StarTech.com 4-Port Dual-Monitor KVM Switch | In Stock | £661.51 |
