StarTech.com 4Port USB C Hub C to A USB 2.0
Quicklinx: D333WS00 Mfr#: ST4200MINIC
Type: USB Hub
Interface: USB 2.0, USB 3.1 Type C
Speed: 480Mbps
Ports: 4
Form Factor: External
Hurry, only 3 left in stock!
£20.83 ex VAT
£24.99 inc VAT
Add four USB 2.0 ports to your USB Type-C laptop with this portable hub. This portable USB hub expands your laptop or desktop connectivity by adding four USB 2.0 (Type-A) ports through a single USB Type-C or Thunderbolt 3 port. And, because it's USB bus-powered, you don't need to connect an external power adapter, which makes travel more convenient and workstations less cluttered.
With its compact and lightweight construction, this 4-port USB hub is designed for mobility. You can easily tuck it into your laptop bag when you're traveling, which makes it easy to expand your connection options almost anywhere you need to. It's perfect for connecting common USB devices such as a mouse, keyboard, or flash drive, right when you need them.
The hub takes up minimal desk space and fits perfectly in hot-desk or BYOD environments.
This versatile USB-C hub is bus-powered, which means it draws its power directly from your computer's USB-C port. This means there are fewer cables to carry with you when you travel because it doesn't need an external power adapter.
This USB 2.0 hub will work with a wide range of computers because it requires no additional software or drivers. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS, so it's multi-platform compatible.
  • Compact Design
    The mini USB hub features a space-saving and portable design, making it easy to carry and use.
  • Wide Compatibility
    Compatible with both Mac and Unix operating systems, this hub provides versatility for different users and setups.
  • Multiple Port Options
    Equipped with four USB 2.0 ports, this hub allows for the simultaneous connection of multiple devices for efficient workflow.
  • Reliable Power Source
    Being a USB-powered hub, it eliminates the need for additional power adapters, streamlining usage in tight spaces.
  • Robust Compliance
    Compliant with FCC, RoHS, WEEE, and RCM standards, ensuring that it meets safety and environmental criteria.
StarTech.com 4-Port USB-C Hub - USB-C to 4x USB-A Hub Adapter - Mini USB 2.0 Hub - Bus-powered USB Type-C Port Expander (ST4200MINIC) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
USB powered, plastic housing
USB 1.1, USB 2.0
8 cm x 17.5 cm x 1.45 cm
99 g
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
USB 1.1, USB 2.0
4 x USB 2.0 Type A , 1 x USB 3.0 Type C
1 x SuperSpeed USB-C cable
FCC, RoHS, WEEE, RCM
8 cm
17.5 cm
1.45 cm
99 g
45 °C
5 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
D333 StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
D333 StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
D333 StarTech.com 2m (6ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.91
D333 StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
D333 StarTech.com 4 Port Portable USB 3.0 Hub In Stock £25.29
D333 StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
Type: USB Hub
Interface: USB 2.0
Interface: USB 3.1 Type C
Speed: 480Mbps
Ports: 4
