StarTech.com 4P Serial to Ethernet Adapter
Quicklinx: HVMGWS00 Mfr#: I43-SERIAL-ETHERNET
£312.93 ex VAT
£375.51 inc VAT
The StarTech.com 4P Serial to Ethernet Adapter is designed to integrate your RS232 devices into modern TCP/IP networked environments. This adapter combines the reliability of RS-232 serial connections with the speed and scalability of 100Base-TX Ethernet, making it a suitable choice for industries requiring robust and versatile communication solutions. With its durable metal housing and advanced protection against electrostatic discharge up to 15 KV, it ensures operational reliability in industrial settings. The device supports efficient data management with features like auto-negotiation, flow control, and full duplex capability, facilitating smooth and reliable data transfer rates of up to 921.6 Kbps. Installation flexibility is provided through wall or DIN rail mounting options, catering to various operational setups. Additionally, the adapter's capability for static IP routing and support for remote management protocols such as Telnet and UDP make it a secure and manageable choice for integrating legacy serial devices into a modern network infrastructure.
  • Robust connectivity
    Equipped with both RS-232 and 100Base-TX interfaces, this adapter ensures versatile connectivity options for a wide range of devices.
  • Enhanced durability
    The metal housing and electrostatic discharge protection up to 15 KV provide a durable solution for demanding industrial environments.
  • Efficient management
    Features such as auto-negotiation, flow control, and full duplex capability ensure efficient data management and transfer rates up to 921.6 Kbps.
  • Flexible installation
    With options for wall or DIN rail mounting, this device server can be installed in various settings, making it a versatile choice for network infrastructure.
  • Secure operation
    Support for static IP routing and remote management protocols like Telnet and UDP allows for secure and manageable network configurations.
StarTech.com 4P Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - TAA Compliant
Device server
Wall / DIN rail mountable
Ports Qty
4
Ethernet, Fast Ethernet, RS-232
DIN-rail mounting kit, wall mounting kit
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
AC 100-240 V
TAA Compliant
6 cm x 17.9 cm x 2.3 cm
400 g
P/N: AT925FM, GC9SF, SCNM9FF, SCNM9FM
Device server
6 cm
17.9 cm
2.3 cm
400 g
Enclosure Colour
Ports Qty
4
Wired
Data Transfer Rate
921.6 Kbps
Network / Transport Protocol
Telnet, UDP, TCP
Routing Protocol
Static IP routing
Remote Management Protocol
Telnet, UDP
Status Indicators
Power, transmit, receive, link/activity
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), manageable, 15 KV Electrostatic Discharge Protection, metal housing, 8 KV Contact Electrostatic Discharge Protection, adjustable parity
IEEE 802.3u, IEEE 802.3i
4 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45 , 1 x - terminal block
EIA/TIA-232
TAA Compliant
External power adapter
AC 100-240 V
15 Watt
Shipping Width
16.6 cm
Shipping Depth
24.2 cm
Shipping Height
5.5 cm
Shipping Weight
600 g
60 °C
5 - 95% RH (non-condensing)
HVMG StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.58
HVMG StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.17
HVMG StarTech.com Serial to Ethernet Adapter In Stock £117.30
HVMG StarTech.com PoE Serial to Ethernet Adapter In Stock £156.44
HVMG StarTech.com 2P Serial to Ethernet Adapter In Stock £179.91
