The 4m USB-A to USB-C Charging Cable by StarTech.com offers a reliable and efficient solution for charging and data transfer. Measuring 4 meters, this cable allows for flexibility in connections, whether at home or in the office, ensuring you can easily keep your devices powered and synchronized. With a robust construction that includes aluminum mylar foil shielding and a thermoplastic elastomer jacket, this cable is designed to withstand everyday wear and tear while delivering consistent performance.
This USB-C cable adheres to USB 2.0 standards, supporting a data rate of 480 Mbps for quick file transfers. Featuring a rated current of 3 A, it is capable of USB Fast Charge (15W), allowing you to power your devices efficiently. The strain relief and EMI protection features enhance durability, making it ideal for frequent use. With a lifespan of 10,000 insertions, this cable serves as a long-lasting accessory for all your charging and syncing needs.
Durable construction
The cable features aluminum mylar foil shielding combined with a thermoplastic elastomer jacket, ensuring resistance against wear and tear while maintaining performance integrity. -
High-speed data transfer
Offering a data rate of 480 Mbps, this USB 2.0 compliant cable allows users to transfer files swiftly between devices. -
Fast charging capability
With a rated current of 3 A, this cable enables USB Fast Charge at 15W, making it an efficient solution for powering various devices. -
Long insertion lifespan
Designed for longevity, this cable supports up to 10,000 insertions, providing a reliable connection for both casual and heavy users. -
Effective strain relief
The cable incorporates strain relief features that minimize stress on the connectors, enhancing durability and maintaining connectivity over time.
- StarTech.com 4m (13ft) USB-A to USB-C Charging Cable, Charger Cord, M/M - USB-C cable - USB to 24 pin USB-C - 4 m
- USB-C cable
- Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
- Length
- 4 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 22/26
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 4 m
- Outside Diameter
- 4.2 mm
- Black
- 153 g
- Connector
- USB / USB 2.0, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 158 g
