StarTech.com 4m USB-A to USB-C Cable
Quicklinx: J1MVWS00 Mfr#: USB2AC4MBKE
Length: 4m
£10.50 ex VAT
£12.60 inc VAT
The 4m USB-A to USB-C Charging Cable by StarTech.com offers a reliable and efficient solution for charging and data transfer. Measuring 4 meters, this cable allows for flexibility in connections, whether at home or in the office, ensuring you can easily keep your devices powered and synchronized. With a robust construction that includes aluminum mylar foil shielding and a thermoplastic elastomer jacket, this cable is designed to withstand everyday wear and tear while delivering consistent performance.
This USB-C cable adheres to USB 2.0 standards, supporting a data rate of 480 Mbps for quick file transfers. Featuring a rated current of 3 A, it is capable of USB Fast Charge (15W), allowing you to power your devices efficiently. The strain relief and EMI protection features enhance durability, making it ideal for frequent use. With a lifespan of 10,000 insertions, this cable serves as a long-lasting accessory for all your charging and syncing needs.
  • Durable construction
    The cable features aluminum mylar foil shielding combined with a thermoplastic elastomer jacket, ensuring resistance against wear and tear while maintaining performance integrity.
  • High-speed data transfer
    Offering a data rate of 480 Mbps, this USB 2.0 compliant cable allows users to transfer files swiftly between devices.
  • Fast charging capability
    With a rated current of 3 A, this cable enables USB Fast Charge at 15W, making it an efficient solution for powering various devices.
  • Long insertion lifespan
    Designed for longevity, this cable supports up to 10,000 insertions, providing a reliable connection for both casual and heavy users.
  • Effective strain relief
    The cable incorporates strain relief features that minimize stress on the connectors, enhancing durability and maintaining connectivity over time.
StarTech.com 4m (13ft) USB-A to USB-C Charging Cable, Charger Cord, M/M - USB-C cable - USB to 24 pin USB-C - 4 m
USB-C cable
Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
Length
4 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/26
Rated Current
3 A
Plated Connector
Nickel
Length
4 m
Outside Diameter
4.2 mm
153 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
1.5 cm
Shipping Weight
158 g
Length: 4m
