With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready whenever you need them while you're on the road.
The long cable lets you overcome distance restrictions and stay connected. You can take notes in a boardroom, catch up on emails in your hotel room, or read in a coffee shop.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
Durable construction
The cable features aluminum mylar foil with braid shielding, enhancing durability and reducing external interference. -
Versatile compatibility
Designed with 24-pin USB-C connectors on both ends, this cable is compatible with a wide range of USB-C devices. -
Efficient charging
With a rated current of 5 A, this cable enables efficient and rapid charging for devices that support high power delivery. -
Environmentally friendly
The cable complies with RoHS, USB-IF, and WEEE standards, ensuring it meets environmental safety requirements. -
Enhanced performance
This shielded USB-C cable allows for charging and supports data syncing, making it a versatile accessory.
- StarTech.com USB C to USB C Cable - 13 ft / 4m - 5A PD - M/M - White - USB 2.0 - USB-IF Certified - USB Type C Cable - USB C Charging Cable (USB2C5C4MW) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
- USB-C cable
- Technology
- Shielded
- Sync and charge, up to 100 Watts of power delivery
- Length
- 4 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Current
- 5 A
- USB / USB 2.0
- White
- 2-year warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/26
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 4 m
- White
- 180 g
- Connector
- USB / USB 2.0, RoHS, USB-IF, WEEE
- 2-year warranty
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £17.53 |
StarTech.com 3m 10ft USB C Cable w/ 5A PD | In Stock | £19.11 |
StarTech.com 1m 3ft USB C Cable w/ 5A PD | In Stock | £11.40 |
StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m | In Stock | £15.26 |
StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable | In Stock | £13.94 |
StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M | In Stock | £10.21 |
