Connect your USB Type-C devices to your computer, over longer distances. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall or car charger.
The non-standard 4-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
Versatile Connectivity
The cable features a 24-pin USB-C connector on one end and a 4-pin USB Type-A connector on the other, allowing for easy connections across a wide range of devices. -
Reliable Performance
Compliant with USB-IF standards, this cable ensures dependable performance for both charging and syncing tasks.
- StarTech 4m 13ft USB C to A Cable - USB 2.0 USB-IF Certified - USB Type C to USB Type A Cable M/M - USB-C Charging Cable - USB A to C (USB2AC4M) - USB-C cable - USB-C to USB - 4 m
- USB-C cable
- Sync and charge
- Cable Length
- 4 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- 2-year warranty
- USB-C cable
- Sync and charge
- Cable Length
- 4 m
- Connector
- USB / USB 2.0, USB-IF
- 2-year warranty
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £8.64 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.27 |
StarTech.com 4m USB 2.0 C to A Cable M/M | In Stock | £16.01 |
StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.94 |
StarTech.com 1m USB A to C Cable - USB 2.0 | In Stock | £9.77 |
