StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC
Quicklinx: 94B4WS00 Mfr#: SMFIBLCLC4
Length: 4m
Colour: Yellow
Select:
10 In Stock
£22.84 ex VAT
£27.40 inc VAT
Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCLC4 4m LC to LC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 4m Fiber Optic Cable - Single-Mode Duplex 9/125 - LSZH - LC/LC - OS1 - LC to LC Fiber Patch Cable (SMFIBLCLC4) - patch cable - 4 m - yellow
Patch cable - OS1
Duplex fibre optic
Molded
Length
4 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x LC single-mode - male
Connector (Second End)
Yellow
P/N: GLCEXSMDST, GLCLHSMDSTTA, GLCLXSMRGDST, GLCZXSMRGDST, JD119BST, MASFP1GBLX10, QSFP40GLR4S, QSFP40GLR4ST, QSFP40LR4ST, QSFP40SR4ST, SFP100BBXDST, SFP100BBXUST, SFP100BEXST, SFP100BLHST, SFP100BLXST, SFP100BZXST, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRST, SFP10GBZRST, SFP1GELXST
Network Cable Type
Patch cable - OS1
Duplex fibre optic
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Molded
Length
4 m
Yellow
Connector
RoHS
P/N: ET91000SM10, ET91000SM20, EXSFP1GELXST, GLCEXSMDST, GLCLHSM10PST, GLCLHSMD10ST, GLCLHSMDST, GLCLHSMDSTTA, GLCLXSMRGDST, GLCZXSMRGDST, J4859C10PKST, J4859CST, JD119BST, MASFP1GBLX10, QSFP40GLR4S, QSFP40GLR4ST, QSFP40LR4ST, QSFP40SR4ST, SFP100BBXDST, SFP100BBXUST, SFP100BEXST, SFP100BLHST, SFP100BLXST, SFP100BZXST, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRST, SFP10GBZRST, SFP1GELXST, SFPG1320C, SFPGLCLHSMST
94B4 StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £21.31
94B4 StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.13
94B4 StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.13
94B4 StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £22.84
Length: 4m
Colour: Yellow
