Connect your Mini-DisplayPort-equipped computer to a standard DisplayPort monitor. The MDP2DPMM4M 4m Mini DisplayPort to DisplayPort Cable features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, enabling you to connect your Mini DisplayPort-equipped laptop or Mac family of products to a monitor or projector that uses a standard DisplayPort connection.
Durable construction
The cable features aluminum mylar foil with braid shielding, ensuring long-lasting performance while protecting against interference. -
Gold-plated connectors
Each connector is gold-plated to provide enhanced conductivity, reducing the risk of signal loss and ensuring high-quality transmission. -
Wide compatibility
This adapter cable is compatible with Mac devices, allowing users to extend or mirror their displays easily. -
Flexible length
At 4 meters, this cable allows for versatile setups, making it suitable for various configurations without compromising video quality. -
High-quality video and audio
Designed for optimal performance, this adapter delivers superior video and audio output for a seamless experience.
 - StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M - 4m Mini DisplayPort to DisplayPort - Mini DP to DP Cable (MDP2DPMM4M) - DisplayPort cable - 4 m
 - DisplayPort cable
- Technology
 - Shielded
- Length
 - 4 m
- Connector
 - Mini DisplayPort - male
- Connector (Second End)
 - DisplayPort - male
 - RoHS
 - Black
 - Limited lifetime warranty
- Designed For
 - P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP
 - DisplayPort cable
- Technology
 - Shielded
- Shielding Material
 - Aluminum mylar foil with braid
- American Wire Gauge (AWG)
 - 32
- Plated Connector
 - Gold
- Length
 - 4 m
 - Black
- Connector
 - 20 pin DisplayPort - male
 - RoHS
- Designed For
                        StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.26 |
                        StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.20 |
                        StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £3.70 |
                        StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.46 |
                        StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £19.66 |
                        StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.91 |
