Connect your Mini-DisplayPort-equipped computer to a standard DisplayPort monitor. The MDP2DPMM4M 4m Mini DisplayPort to DisplayPort Cable features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, enabling you to connect your Mini DisplayPort-equipped laptop or Mac family of products to a monitor or projector that uses a standard DisplayPort connection.
- StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M - 4m Mini DisplayPort to DisplayPort - Mini DP to DP Cable (MDP2DPMM4M) - DisplayPort cable - 4 m
- DisplayPort cable
- Technology
- Shielded
- Length
- 4 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - male
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Gold
- Length
- 4 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.27 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £14.83 |
StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.82 |
StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £11.14 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £19.60 |
StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £13.58 |
